2005 Ford Freestyle Low Oil Pressure Problem
Recently my 2005 Ford Freestyle (38k miles) has been starting rough in cold weather. The oil pressure low light comes on for about 5 seconds, then it stops and idles fine. What could be wrong?
Are you using synthetic oil? That's what I use, and I'm wondering if that's the cause of it.
I'm assuming your oil level is OK?
TSB
06-20-7 LONG CRANKING TIME OR NO START ON INITIAL START ATTEMPT - VEHICLES BUILT ON OR BEFORE 6/6/2006
Publication Date: September 29, 2006
FORD: 2005-2007 Five Hundred, Freestyle
MERCURY: 2005-2007 Montego
ISSUE:
Some 2005-2007 Five Hundred, Freestyle, and Montego vehicles built on or before 6/6/2006 may exhibit a long cranking time or a possible no-start on initial start attempt. This symptom may also be accompanied by the malfunction indicator lamp (MIL) on with diagnostic trouble codes (DTCs) P0300, P0316, P2107, and P2110. If the vehicle exhibits the long crank / no start issue, reprogram the powertrain control module (PCM). If the vehicle just exhibits these DTCs without the long crank / no start symptom follow normal Powertrain Controls/Emissions Diagnosis (PC/ED) manual diagnostics instead of this TSB.
ACTION:
Reprogram the powertrain control module (PCM) to the latest calibration using IDS release 44.24 and higher or 45.3 and higher. This new calibration is not included in the VCM 2006.9 DVD. Calibration files may also be obtained at www.motorcraft.com.
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage And Emissions Warranty Coverage
OPERATION DESCRIPTION TIME
062007A 2005-2007 Five Hundred, Freestyle, Montego: Check For Diagnostic Trouble Codes And Reprogram The Powertrain Control Module (Do Not Use With 12650D) 0.4 Hr.
Big thanks!!
