Hyundai Tiburon Engine Questions
2004 Hyundai Tiburon
It looks like a 4, but I am told it is a V6. I have only the photos to go by, so it's hard to tell. Any input would be appreciated.
http://img170.imageshack.us/img170/404/feb0820048ck3.jpg
http://img404.imageshack.us/img404/654/feb0820049mg9.jpg
My question(s) is I have yet to have my timing belt changed. From what I am told is that it's not covered under the warranty. Is it bad that I havent had it changed yet? How much longer do I have? Should I get it changed at the dealership? They quoted me $600 to change it, or should I go to a smaller mechanic? What is an average cost to have this done? The large majority of my miles are highway. I drive 85 miles/day to work...75 of which are highway. What would happen if the belt snapped?? Someone told me that if the timing belt snaps on Korean cars than the engine will no longer run, ever.
Please help me with this. I dont make a ton of money and cant afford a new car...at the same time $600 for a new timing belt is extremely steep as well. Any and all advice will help. Thanks!!!
dont be fool search around for the best price and quality of product, 600$'s is wayyyyyyyyyyyyyy to much
adios
A set contains of Timing Belt,Tension Assembly,Idle Pulley,Water Pump Assembly,Water Pump Gasket,Power Steering Belt,Water Pump Belt, and A/C Belt
I suggest doing it all at once if you are doing it at all!
2.7L
2.7L Timing belt package
2.0L
2.0L Timing belt package
hope this helps a little or alot...and correct me if im wrong about anything...
If it is not an interference fit, the valves won't come into contact with the pistons and the valve-train will be ok.
Te $600 cost is not that bad, really. As the others responded, it's mostly the labor in removing all the components to get to belt. Also stated, the common practice when changing out the belt is to replace the water pump. Not that the pump goes bad at the same time, but it's really for insurance. The area is open anyway so might as well replace it; the labor for it should be free or very little. You don't want to do a belt replacement then a month down the road the water pump takes a dump. Then you looking at another huge $$ repair.
Hope this helps.
Can anyone confirm this?
if it is a turbo car, i just have to buy a good turbo.
if it is not then i have to buy turbo kits.
i want to know if it is turbo car.
so i won't spend big money to search for it.
thank u!
I'm stuck.....
Before you turn the key all the way to start, just turn it to the ON position then turn it off. That will run the fuel pump for a few seconds. If you do that a couple of times it will re-establish pressure in the line and you should start right up if that's the issue.
When you turn the key you should hear the electric fuel pump running for a few seconds. If it is that you're leaking fuel pressure, this key trick will be a good workaround until the leak gets bad enough to be easy to find.
My son is a Hyundai master mechanic.
My Tiburon will eat GT Mustangs.
That is not to brag but to give you a little background.
Your engine is a 2.0 litre 4-cylinder.
Lots of performance parts available. Go to Next Generation Motorsports.
The problem I have is thusly. My car is dumping fuel into the cylinders and rotting out the exhaust components. I'm on my 3rd cat and 2nd flex pipe in less than 3 years. I've replaced the fueltank, fuel pump and all four injectors. Still doing the same thing.
Currently I've switched to Elantra injectors, same engine size, but less fuel flow to save fuel. The car used to get about 700km to a tank (53L) if driven gently. When the problem first came about and I was popping fuel injectors thanks to the bad fuel tank (rust/water from top side hole which Hyundai didn't even investigate, they just tossed in some chemical at $80 a gallon to try and flush the system...), I was lucky to get 400km to a tank. Now with the Elantra injectors I'm getting about 525km. However, she has her power back. When pushed heavy, I can kill a tank in 450km and still get top performance, but again, still dumping fuel intermittently.
The engines intake system has a Bosche Electromagnetic Air Throttle Valve which is apparently STOCK EQUIP on a Korean engine, yet here.. the techs at Hyundai in Stoney Creek didn't even know what it was. Couldn't order it. Hyundai Mississauga wanted $800CAN to import it. I got a used one from a scrap yard for $50!!! Works fine!!
I'm at my wits end. Been three years driving her like this.. Poor thing. :sick: She's in great shape otherwise. Body's mint, one or two dents thanks to Toronto's bad parkinglot drivers... only 118,000km (75,000mi)on her. I love this car. Completely agree.. Even stock, this car kills turbo Integras, Mustangs, Lexi.. Even some older Porches. Just the right combination of power and torque jammed into a small compact economy sports car. YES, "economy sports car." Its very economical, and extremely sporty. My old man loves this thing more than his 'Vette, a '74 Stingray with custom 454-V8!! Which is like driving an ocean liner to work. Just turning it on takes a litre of gas!!
Randy and Tiamat
I have a 2005 Hyundai Tiburon GT 2.7 six speed gearbox which has all of a sudden developed an issue with the speedometer and trip meters not working.
I have changed the speed sensor which is on the top of the gearbox but still it doesn't work. I have also checked all the fuses and they are fine so now I am hoping someone could point me in the right direction.
Kind regards,
Vincent
