2006-2009 SE 6 cylinder Sonata Power!
Let's hear about the power of these cars! What are your experiences? I saw on youtube a few 60 mph runs that are crazy. It looks like it must be hard to keep the car under 70 on the highway.
It's fun to drive and only drawback I see is it revs to easily 2000 - 2500 rpm when you take off slowly from a traffic light and feels as if it struggles a little bit when it starts rolling. I am not pushing too much gas but still feels little sluggish... Once it goes to 30 and above, it's very smooth and quiet. Not sure whether its becos the engine hasn't broken-in yet (mine is close to 1000 miles now).
I am having a bit of trouble with the TPMS system ... dealer inflated and reset the sensor twice ... in two days. Any suggestions
I want to figure out whether there is some tuning that I have to do (it's a brand new one but has been sitting in the dealer's lot for more than 3 months before I laid my hands). Mine too will take off really fast if I pump it up to 3500+ rpm but I am just trying to feather it and it feels little sluggish... Not sure whether it's becos of the new engine or sth else!
If you're getting up to 2K or 2500 rpm in 1st gear the car shouldn't seem sluggish at all.
Would be interesting to know why does it go into 2nd gear if someone starts slowly? I would expect it to go in the first gear until the rpm reaches a certain level or maybe, there is some other theory behind the gears shifting process?
Try, for a month, to give it a bit more gas when starting (it won't materially affect your MPG) and don't pump the gas pedal, apply steady pressure.
One of the dealers said it needs 89 Ocatne gas....I should not put 87 Ocatne..where as per my user manual... 87 Octane gas is fine.
Where as the dealer from whom I bought the car asked me to get the car tomow. to their service center..... as they said they r going to fix it..if not then replace the car. Where as its not typically expected of a new car if it really passed Quality tests.....
Let me know if anyone had similar problem in the past......??
Don't get me wrong, I am big fan of Hyundai, and love my Sonata... .but the Nissan/Infiniti VQ line of engines are definitely stronger, particularly in the lower rev band.
1) If I am driving in 50 MPH and I come to a complete stop, the car does change to a lower gear it simply turns off the engine
2) If I am driving in 40 MPH and then If I press the brake to reduce the speed and then make turn and then press the gas pedal to increase speed, the car just jerks for a few seconds before changing gear.
I have a feeling that the car has problems going from 2nd to 1st bear. Does anybody have the same problem. Are there any solutions?
Sridhar
Do you know how long it takes to fix it?
happened to me before. With catylitic converters the system may be thrown off.
Just the opposite happens if you open the flow you will gain HP and MPG like
when headers are installed, have done that also. I used to work on my own vehicles
but with all the new junk they have on them it takes a computer now.
