Thanks Martina
Do you happen to know if/when you had spark plugs and wires replaced on your Rendezvous? While this is not an official GM diagnosis, I hope it's helpful as you gather information. If you decide to work with a dealership on getting your starting concern looked into, please let us know by emailing us at socialmedia@gm.com (include your name and Edmunds username, contact information, and the last 8 digits of your VIN).
Sarah, GM Customer Service
ps: Just a note, the gas pedal in todays cars only opens the throttle body to increase air to the fuel being supplied by the electric fuel pump. The days of a gas pedel are gone as we know it. Hope this helps
If it does turn over does the problem happen at any time (when engine is cold or warm) or does it happen only after engine has been warmed up?
If your alt light did not come on, then it was not the alt, Auto part stores cann do the complete test in 15 minutes, alt, starter battery for free.
The other issue is electrical.
Another cause is the fuel pump is going bad - was the fuel pump tested?
MY 2004 fuel pump died long ago. Have u been driving and it has felt the car has lose power and then just appears to be fine, its like a stall and then the car picks up again - that fuel pump going.
after that my husband had to turn the key 3 times before it caught.It did sound like it was trying.
Good Luck.
Way past frustrated with our 2004 Rendezvous. We have had it seen by many and still having problems with high idle, parked and driving. Also it won't start right away after even the smallest trip, across the street, down the street. UGH!! We have spent soooooooooooo much money on this POS,
Someone, anyone, please help!!!
For the high idle problem I woulds suspect it may be TPS (Throttle Position Sensor), I have had it a couple times on our Pontiac version. In our case the vehicle starts ok, but while driving the Tach may go up to around 2K RPMs and stay there until vehicle is restarted.
For the starting problem is this after driving for a while and then making rather short stop (5 Mins or so) and then doesn't want to restart? If so I have never heard of a real fix. What I do is after it fails the first time, the second try I hold key in start position until it does start, may be quite a bit longer then usual. My experiance seem to be the more 'times you try' the worse it gets.
We have replaced the following: ignition relay, throttle position sensor, mass airflow sensor, wiring harness from the connector to the top of the gas tank.
We are holding our breath and praying our problems are over
And Thank you so much for your time and help
