Thanks...
regards,
john
I only mention it since you neither appear interested in seeking help for a problem nor in offering solutions.
Best wishes!
I am new to this site and I have just joined you.
I own a 05 Armada and I am happy with it. I bought it 7 to 8 months ago and the only problem I faced was the brake issue Which no longer exist.
Just 2 days ago, I faced a problem (it may not be a problem) where the air bag light (signal) in the main driver board is signaling all the time. I checked the user manual and it mentioned that the light should be on for 7 seconds after you start your car. But in my case, it is on all the time.!
Any one faced the same matter?
I appreciate your feedbacks.
Steering wheel vibrates when you apply breaks.
Radio buttons stick.
Driverside window literally drops into the door
Heat is HOT - not 72 degrees as programmed
AM radio pops (static) every time I hit a bump
Flat tire alarm sounds everytime it is below 20 degrees (this is getting really annoying)
Various alarms sound for no reason (I have my seat belt on - my door is ajar acording to the display - i get out of the car, checked the doors and they are all closed, yet the alarm still sounds)
Doors do not lock after one minute as programed
Lights do not come on automatically as programed
That's all i can remember at the moment. Do I have an electrical problem or something?
My dealer was the nicest guy at sale - now he won't even return my calls.
I can take it to another closer dealer for repairs - is this sugested!
Thanks for your answers!
Now I have an '04 Armada. My 7th and FINAL nissan. Has the entire lineup of problems: what I named "earthquake" brakes (like driving in during a 8.5 Richter quake), window auto down, DVD console fell down, gas gauge never full, rolls back while in drive, Accelerated wear on the tires from the earthquake brakes, big clunk when shifting into gear from park, and what I call the "suicide HVAC option", wherein this piece of #*it will circulate exhaust, a/k/a carbon monoxide, into the cabin when the heater is on and the thing is parked. All this in under 20K miles, and for only $49,000.00
So I called the drooling imbeciles at nissan corporate in LA. who failed to return my calls. So I turned on the "pit bull personality" switch I was born with. Left a memorable voicemail with their vp of marketing. Then one of their lackies called back. Are you ready? I told them I wanted them to pay for an SUV rental while they worked on their sled. I further demanded a full service fro my loss of time and aggravation. Here is what they offered to this 7 time nissan buyer: NOTHING. (I did strategically "forget" to mention the 94 [non-permissible content removed]-beating I gave them)
To paraphrase the line from Cool Hand Luke: "Some corporations; you just can't reach." So I just finished with visit number one for the brakes. Give me about 60 days, and these morons are going to get a demand from a lemon law lawyer.
Bottom line everyone, nissan is a company which obviously cares nothing about even 10 year long/7-vehicle buyers, so why would they care about anyone else.
Here is the best fix for this sled of a company:
Document EVERYTHING - every call, every detail of conversation, every name of every nissan employee with whom you speak. Print similar complaints from online sites. Stay on their [non-permissible content removed], and show them no quarter.
Then, after the third visit, get a lawyer, and give them the same karma they deserve. SUE THEM AND KICK THEIR [non-permissible content removed]!
I also started having issues with the internal marker needles that show battery life is left on the battery and the RPM's marker needle do not light up when the lights are on.....the dealer said that they had to order a new dimmer switch????
Anyone else have this issue?
Please help!
Everyone should check their armadas to see if they experience lethal exhaust fumes in the cabin. While parked, turn the heater on and set it to recirculate. Exit the vehicle and let it run for several minutes. Then open a door and see if you smell exhaust fumes. Then, of course, if you do, immediately turn it off, open all windows and doors and allow full venilation of the vehicle for several minutes. Turn the heater off. It seems to occur only when on "recirculate."
I am going to hook a up a CO2 sensor to a power inverter to the inside of this $49,000 sled to confirm the extremely dangerous carbon monoxide risk. Both I and my wife have both experienced headaches when the heater is on, a preliminary syptom of CO2 poisoning.
Further, I will be contacting the CPSC (Consumer Product Safety Commission), and the NTSB (National Transportation Saftety Board) in DC to report this danger, as well as nissans appalling refusal to check their armada sleds for a potentially killer problem.
As I said, nissan could care less about it's customers, which explains why I truly despise nissan.
While parked, with the vehicle running, and with all the windows and sunroof closed, turn the heater on and set it to recirculate. EXIT THE VEHICLE. Let it run for several minutes. Then open one door and see if you can smell exhaust fumes inside the cabin. Then, of course, if you do, immediately turn it off, open all windows and doors and do not enter the vehicle until it is fully venilated after several minutes. If you do not detect exhaust fumes inside the cabin, set the venilation to open (not recirculating), and follow the same procedure to confirm if you are driving a potentially lethal Armada.
Nissan is typically unresponsive to this owners compliant, even though it is a potentially lethal problem. This is just more info which my lawyer will be using to force nissan to buy back this sled. My causes of action will include personal injury claims for the headaches we have suffered already, before I discovered the problem.
This settlement is going to cost them much more money than the $12,000 in payments we made on the lease; a lot more.
2) Tire sensors below 20 degrees. That means your tires are dropping below 28psi. Very common for tires to lose pressure when temps drop. I think it's something like 1-2 psi per 5 or 10 degrees drop in temp.
3) The brake issue is resolved, even on my 04. I had the final kit put in 12K miles ago and no issues. As for braking power mine stops way better than any Expedition or Yukon I've ever driven.
-mike
I am looking at buying a new 05 Armada. What are your thoughts?
I paid $36 with everything except the Navigation.
Also I've sat idling mine for hours on end, no problems so it's only YOURS that's an issue.
-mike
Nissan is committed to providing the highest levels of product quality and customer satisfaction. We know that towing a trailer may have been an important consideration in your vehicle's purchase. In new Titan, Armada, Pathfinder, Frontier, and Xterra vehicles, Nissan recently introduced enhanced electric circuitry which may further protect your vehicle from damage or fire caused by a short circuit wiring or mis-installation of trailer lighting or electrical accessories. This is to advise you that Nissan is making this production enhancement available to you free of charge so that you will have the same protection should you ever tow a trailer with a defective electrical system.
-mike
I acquired a 2004 Armada on October 24, 2004, and I am about to dump the piece of ####. I have the same gamut of problems you 've read about, including I don't care attitude from Nissan and its delearships. The service you get is dictated by Nissan USA. Do not expect a loaner car when you take your car in for repairs covered under warranty. It is a rip-off. Once bitten forever shy. Do not buy or lease, because once the deal is completed and you have parted with your money the manufacturer does not care if you roast. Do not make the same mistake that I made.
I have been in the dealership more than 35 times since I bought this truck. I have problems from cd player, brakes,auto levelling suspension, clearance at the back (height of the truck too high), window switches, door handles, air penetrates on the window, tire pressure sensor keeps beeping etc. etc. etc......Some of this problems are still outstanding. My main concern is the wheel alignment. Even after this truck is aligned, I bet you the alignment will be off again in 3 to 5 weeks. I try not to let my family ride this crappy truck because I am not sure if it is safe. I am about to give up and bring this concern to a lawyer. Nissan north america is a waste of time. they dont give a damn about us, I even wrote them a letter and nothing happen, but they forgot it is us who feed their families. Any suggestion? anybody? please help.
There's also JD Power star ratings for reliability for most cars here, but you have to look at each SUV individually to see them.
BTW, after having the latest brake fix done last June 2005, I have had absolutely no problems with the brakes.
Funny how the rest of the problems are all very minor things, usually present at some point in most vehicles. What a great engine, tranny, safety, and electrical system this vehicle has . . . the stuff that counts the most for me.
Also, yes our driver side seat squeaks! Drives me crazy.
So, next time you get to replace, make sure the frame is completelly cleaned out from older dry silicon before putting back the new one.
-haro
Other than the brake problem and now this squeak I love the truck. I had the brake problem fixed at 3500 miles and now the brakes squeak some. The service advisor told me there's only about 15% front brake pads left? huh??? At less than 15k...less than 12 if they replaced the pads when they performed the service bulletin about the brake judder... less than 15k and need new pads... does that sound right? I don't ride the brakes or drive it like a corvette. I have one of those so no need to.
Also, the service advisor was reluctant to work on my brake pad issue at first. I went one level higher and they presented the problem to Nissan. Nissan paid to replace pads, hardware and resurface rotor. No more brake squeal.
I see all these posts from unhappy Armada owners.. For the record: I'm very pleased with my Armada and the service recieved from my dealership.
I think that people are more inclined to post when unhappy than the rest of the Armada owners are. I don't know how many have been sold since 2004, but I'm willing to bet it's way up there. Just about everyone I've spoken with is very happy with their Armada.
Good luck with your search.
I was going to drive it somewhere so I knew I had to check the tires first. I then decided to start it since it had not been started for a few weeks. It would not turn over. So, I jumped it with the 02 Mustang which was next to it in the garage. (The Mustang's battery was much smaller but it did the job.)
We drove it wherever and got it back home just fine. I had also noticed that the interior lights were not working so I took it to the Nissan dealer. They called to tell us that the "body control module" had failed which would have to be replaced at a cost of about $550. Fortunately, we had the extended warranty which covered the cost less $50 deductible.
After picking it up, we noted that my single key would start it but my wife's would not. Her remote would also not open the door. The dealer suggested they need to be reprogrammed. He reprogrammed them at no cost and the big truck is doing fine.
The dealer also stated that the battery had likely failed because of the control module failed.
I'm posting this here so others may be aware of such a failure and it's symptoms. If your battery goes dead for no obvious reason and/or one or more of your keys/remotes do not work, and/or interior lights/door locks, etc. don't work, it could be the body control module is gone.
This is the ONLY major failure we have had although the brakes were serviced twice. We are generally happy with our big truck. Guess they built a few that are ok.
81 Trekker
Does this sound familiar to anyone and what does it suggest. There is no smoke or an odur coming out??
Sorcisto
there has never been a vehicle produced that as poorly designed and built as this vehicle.
