Honestly though, it could be a ton of things and I would not want to be in your position as the stalling could get you killed.
My 2004 did the same thing in the first week. The dealer never programed the fob to the vehicle. So it could be a problem with the key or the antitheft box.
Good luck. I hope your dealers are better than mine.
I hate hear that you are having such problems. I have spent several years under the hood of vehicles and this problem sounds simple. When does it shut off? Is it at a red light or stop sign or when you are going real slow? If so have them test you alternator, it could be it is bad or going bad and it is not keeping your battery charged so the vehicle shuts down. They should have already checked this but if I know dealership service departments they have not. If they give you and grief just find a local garage any ask them to check the alternator. I wish you were close by I would love to help.
I recently bought a 2005 Nissan Armada SE, 45,000 miles. The front AC and the first row floor AC work perfectly. The rear air conditioner has no air flow. I checked and re checked the AC button functionality. I replaced all the fuses pertaining the to HVAC and blower circuits. Nothing has worked. Before going to nissan and paying out my nose...does anyone have any idea how to fix this? Please respond! Can you email me also at gabriel.gengler@gmail.com?
Have you checked the circuit with a tester to see if power is getting to the unit? Sounds like a blown motor but to guess at something like this without testing a few things is like shooting a shotgun in the dark.
-mike
-mike
-mike
-mike
Not sure if this helps you but figured you might want to know.
I would lean toward a faulty ignition module or a faulty key-code. This is common on some early anti-theft coded keys on Subarus in the '04-05 model years and guess what? Nissan and Subaru source a lot of their components from the same place so I'd start there.
-mike
Did you notice if it was the front or rear brakes that were burning? It seems that perhaps you left the parking brake on or depressed it inadvertently?
-mike
-mike
Uh..I bought the extended warranty.
So far, not happy with the 2005 Armada.
-mike
-mike
I guess it took being persnickity to get them to budge because guess what?... There was a problem with the ABS. And they knew about it. It took 4 visits to the dealer for Infiniti to authorize the warranty repair!
To be fair, I may not have explained things correctly to the dealer. At first, I too thought it was a problem with the emergency brake. If the emergency brake light comes on, isn't it reasonable for the lay person to assume there's a problem with the emergency brake? How the heck would I know what all the error codes are and what all the flashy blinky lights mean? I'm not a mechanic.
But I do find it really hard to believe the dealer doesn't know about this problem now. I did my kicking and screaming to Nissan about a year ago, and it seems that other people in this forum have been through similar things. Your dealer should look at his tech bulletins again.
I wouldn't go quite so far to say the Armada/QX56 is a lemon, but it really has had more than it's share of problems. Am I too demanding to want my brakes to work, or not have the car suddenly grind to a stop on the freeway?
On the bright side, I'm really happy with my new 2008 Land Rover I traded for the Infiniti. Just hope I'm not going from the frying pan into the fire.
SUVs and Smart Shopper
-mike
-mike
Motorsports and Modifications Host
