Rocker Arm Gone Bad
ruplinruplin Member Posts: 1
edited March 2014 in Pontiac
I recently found a loose rocker arm on the front of my 02 Bonnie. I thought it was just a lifter tapping until I removed the valve cover and found a very wobbly and loose rocker arm. The push rod is loose to. My problem...do I have a damaged lifter or has the rocker arm gone bad.
  • joel54joel54 Member Posts: 3
    I have bad bushings on the front lower control arm on my 2000 bonneville. My dealer says I have to buy the entire arm. Does anyone know where I can get just the bushings?
  • imidazol97imidazol97 Member Posts: 27,740
    MOOG Part # K6580 {Control Arm Bushing Kit}
    Rr Susp; Lower; To Frame
    $15.84
    Found at rockauto.com. Drill through the choices for identifying your car and pick "suspension."
    Go to a quality alignment and repair shop. They'll take care of it, including a recheck to see what the problem is for sure. I'm surprised the dealer doesn't want to do the parts.
    The part number you gave me, k6580, is for the rear control arm. My problem is with the front lower control arm. Thanks for any help you can give me.
