Nissan Sentra Starting and Stalling Problems
Are you having any starting or stalling problems with your Sentra? We can talk about them here.
See Also: Solving Intermittent Stalling Problems
I have a '96 Nissan Sentra GLE. For the past 2-3 years (I've only had this happen to me about 5 times total). When going down the road, my car will all of a sudden just stall/die. The engine will just completley shut off leaving me with hardly any brakes and stearing to control my car. I've noticed that it only happens when it is somewhat hotter out and when I am getting low on gas (but not when my red light is on). The most it's ever done this is 2 times in 1 day. Once I finally come to a complete stop and am able to put it in Park, I can then start my car and off I go!!! Not only is this annoying but dangerous as I loose a lot of my brakes and steering. Please let me know if anyone else is having this issue!! Any suggestions anyone????
I got stuck on the freeway once after my 04 Sentra shut off unexpectedly after coming to a stop because of traffic. All I can say is that experience was horrible! I almost got hit several times after traffic flow resumed.
Nissan seems to have a problem with emissions systems. I had to replace several parts that I later learned where under and extended warranty (150000 miles). Its been a hassle to get my money back. No one is willing to help!
Service is very poor at Nissan, you would think they would want you to come back.
Any advise is highly appreciated.
When the car is still warm after some travel, it will do the exact same thing, but after a shorter time/distance - around 5 minutes. If the car was just on a short hop, and is still up to temp, it works fine. It's just when the car has sat for over an hour or so.
Note: If I crank it over too soon after it dies, it just cranks, with no firing, and I have to wait an extra amount of time for it to restart,, but will still die again, and go thru the cycle. Anyone have any ideas?
BTW, replaced fuel filter, plugs, wires, cap and rotor when this started.
Take care,
Robyn
I am a new driver and new owner. no ideas whats going on. It is a matter of safety because it stops while running.
any suggestions would be greatly appreciated
When the car is on drive and moving, it drives well, however, when I stop at a traffic light, it goes back to "Neutral mode" and does not move. I have put $.1500 until now on the car, but the problem still exists and no, mechanic including Nissan dealership can identify the problem and fix it.
Can anyone who owns a similar car and who may have experienced the same problem, advise me? I can't afford to go to Nissan Canada or a mechanic once again - I just got laid off from my my job! To everyone out there: Please, Please think a 100 times before you get a Nissan.
watch this video might help..
http://www.youtube.com/watch?v=7OhBebJ-Ksc
i will do this tomorrow first day in the morning. good luck!
My 06 sentra started acting up a couple weeks ago. When it is cold (first thing in the morning) it is difficult to start. Sometimes taking multiple tries and up to ten minutes.
I can usually get it started and once I get it going - it runs just fine. I can usually get it started after work within two tries (a lot of times one try). Again it runs beautifully once it gets started.
If I get home on time (before 6PM) and dont start it again until morning its difficult to start. I have noticed that when I get home late and there is less time between starts, it was ok to start in the morning.
My mechanic neighbor was nice enough to clean the throttle body for me and other parts and it seemed to start fine once he did that. But once we turned it off it would not start again. then it did start later.
We are very confused. He is going to check it with his computer tomorrow - but we were wondering if anyone has had this issue or has any ideas on what could be going on. Please help.
heres a little light on the situation
Why is my car doing this. I am a single parent and cannot afford to get a new car so I need to keep this one going but I also can't afford to keep putting money into it if we can't figure out what is the issue. Can someone please help with some advise?
I suggest you visit the junk yard...the sensor is not difficult to replaced as it sits on top/near attached to the main air conduit.
I'm kind of in a tight bind here not sure what route to take on this one...
I have a couple ideas but want to def get some input here.. My ideas include getting different throttle body leaving TPS unhooked or possibly swap out with a 2002 sentra throttle body with the different TPS and possibly just snip my connector and attaching the other connectors for this TPS..
Plz if anybody could help me out with this one I be really appreciated with it!!
I could possibly help u out also if u can help me out i've done plenty of car work and know a d**n good bit about them
