Isuzu Trooper Oxygen Sensors
Where are the Zone 1 & 2 oxygen sensors loated. My OBC error says change them.
Bill
Bill
Bill
If your trooper is 2.6 lt 4cylinder, the O2 sensor is located at the end of the exhaust manifold. It has one wire with a connector. The O2 sensor indication that comes on on the instrument dash is triggered by the odometer at certain millage. You need to remove the hex bolts where the light is located and you will find a switch, just move it and the light should go off. Hope this can help. If your trooper is V6, then two sensors are located one on each exhaust manifold.
