Toyota Sequoia CD Changer Stuck!
I have a 2002 Toyota Sequoia and I have the 6-Disk built in disk changer and my disk seems to be stuck. I cant operate the CD player I keep getting the error 3 message. Can anyone help?
Or replace it with an aftermarket one.
You may get lucky with one of the tricks listed in the Stuck CD Guide, but those tips mostly work with single disk CD players. Here's the link:
How to Remove a Stuck CD
There are two screws behind the air conditioner vents on either side of the cd player, remove them. Use a screwdriver to pull off the face plate. The cd player should have 4 screws holding it in place, remove them. Disconnect the radio from the back you will have 3 to 5 connections depending on the model of your Sequoia (Toyota connectors are very easy to connect and disconnect). unscrew the two screws on top (really small screws) there should be 3 slide clips at the front face of the cd player holding down the top cover, raise these clips slightly and pull off the cover. You should be able to see your cds. You will not be able to save them. Break them in pieces with a pair of cutters and carefully remove them (I stress careful) from the unit. Replace the cover, plug in the connectors to the cd player and screw the mounts back.
Everything should work fine when you turn your key.
I tore into my sister's cassette player one time when a tape was stuck and used some cutters to break up the cassette and get it out. Her radio still worked but the cassette player was trashed. :shades:
Thanks for the instructions!
All this mechanical stuff like CDs (and hard drives) need to disappear and go solid state. Too many bits and pieces that can break or get misaligned on the players.
Just wanted to say a BIG thank-you for your tip on stuck cd.
You are a genius in my book and it worked perfectly just as you said...first time and so easily just pulled the cd right out.
THANK YOU, THANK YOU!
So I have the top plate off, but the cd slot itself is closed and won't allow me to manually eject the cd. Any ideas on how to open that?
The instructions to take the radio out were almost exactly like my car! We were able to get to the CDs but the changer is out of alignment and won't load any more. At least we were able to get my CDs out without damaging them. Thanks for posting this so we could do it ourselves!
