Nissan Sentra 2008
Does anyone know if the 2008 Sentra has a timing belt or timing chain?
If its a belt, do you know the recommended service inspection/replacement intervals?
It's a 2008 Sentra SL.
Does anyone have any advice for us, either how we can get the dearlership to fix this under warranty, or fix it ourselves?
and this is the 5th trip back to the dealer. anyway anybody else have that problem???
The other thing I noticed is when I am going down the road at what ever speeds and I come to a stop I hear and feel a clunk. The harder you brake the worse it gets...Any ideas on this one?
I hate to say it but for a foreign car, I would NOT let any one, or tell anyone to buy a Nissan. Even Nissan themselves, when you call them for help, it is ridiculous, it takes them 2 days to call you back then when they have to check and have a rep call you and you ask them a question it take them a week to call you back...It's a joke. I am just totally unhappy with the whole thing.
The dealership thought it was a loose fuel line, but it did not make the sound go away. Anyone have any ideas or similar problems?
What transmission fluid does it call for and can anyone recommend a great synthetic?
M. Karns
Yes i have a 2008 Nissan Sentra and when I put in drive it also clanks. I am also hearing a loud flem type noise once I start driving then it goes away. Where you ever able to fix the problem?
I have this issue as well with my 2008 Nissan Sentra. I just took it into Nissan and it turns out that one of the piston rings came apart. The engine will need to be rebuilt and they've quoted me 8k!!!! Also, they are asking for maintenance records stating that if I am not able to provide them, my warranty may not cover the work even if it is a faulty piston since there is no proof that the car is maintained. My advice is that you make sure you have all your documentation & take your car in before its too late. If you don't have documentation, consider alternatives because Nissan will now charge me the diagnosis fee even if I don't leave the car there to get the engine rebuilt, which will run around $400. Please learn from my mistakes. There is obviously no way in hell i will ever purchase a Nissan again ever. I have had mitsubishi and honda in the past with no issues like this. I have only had this car for 10 months.
New here and just wondering if anyone could answer my question. About a week ago while driving my 08 Sentra, then engine began making a loud noise. Sounds like its not running smoothly and makes a rattle when decelerating. Didn't know if anyone else had experienced this or if anyone knew if it was a cylinder not firing correctly, etc.
Thanks for any help
(like a golf ball size rock hit the floor board) when you start from 0 mph to 8 mph or while turning from a stop. It was a bad front passenger Strut mount at 15,000 miles( under warranty) after the new one was installed the noise started again a few days later they took the assembly apart and lubed it. It now may be from one of the rear strut units. Also when braking 15mph or under to o mph... there is a hum from the brakes or tranny that was not there until the last 3 weeks, they said its nothing. This car is not driven hard at all. hope this helps. Over all I really like the car so far.
(Note: This is not the dome light in the center.) I would be grateful for any help to point me in the right direction of places to try. I've struck out everywhere so far.
