Quick Links
Do you currently own a 2019 or newer RAM pickup? A reporter would like to speak with you. Please reach out to
[email protected] by 1/27 for more info.
Please talk about the BMW X6 in here.
First Look: 2009 BMW X6 xDrive50i
But who am I to complain! If that's what people want, it's a good thing!
OW
I really like the x5 and will be taking a x5 in probably the next year or2 but first really want to see the x6 in person because first of all I don't need a 3rd row seat even the 2nd row will probably be empty most of the time.
Despite the fastback roof line, the rear seats offer headroom that's only 1.1 inches less than you'll find in the second row of an X5.
Is the front drivers seat head room same as the x5 or lower?
can't wait to see it in person I don't know why every1 seems to say that x5 x6 are soccer mom car.
But the negative things i read abt the x6 compare to the x5 is
1.x5 already doesn't have much ground clearance so probably more less for the x6 but that has to be expected since they call it a SAC. sport activity coupe
2.less head room in the back seat then the x5 but 1.1inch doesn't make a big difference not sure whats the difference for the front seat head room compare to the x5.
3.less utility space but that doesn't bother me at all.
4.side windows has down sized specially the second row
5.it's even longer than the x5.
6.The steering wheel features BMW's uniquely styled shift paddles shift which i wonder might bother while turning the steering. but since those m5 m6 has those shifts i don't think that will be a problem at all.
7.not sure how better the v8 twin turbo will be to the the current naturally aspirated v8.
After all the negative side of the x6 I can forget it all after seeing it in person I hope so.
I'm not sure how you can seriously brag about dynamics when discussing a 5000 lb 66 inch tall vehicle
So how can they??? :confuse:
So do you agree with all my negative points or not?
Do you have any of your own negative point the x6?
I also heard abt rear visibility problems and blind spots.
The negative points that do bother me a little is also the visibility and down sized side windows, other points will be no concern at all specailly for those whos is going to get this vehicle.
Surely styling will be the biggest concern for getting this vehicle.
Considering that a fully loaded X5 4.8i is over $76k and a fully loaded 535xi wagon is $73k, that price range is entirely believable. Still, it would be nice to see the actual price list.
The torque and the nearly flat power curve are the deal changers. There should be a big difference in performance given that the new engine makes 450 ft-lb of torque and 400 hp at 1,800 rpm.
The normally aspirated V-8 makes peak torque of 350 ft-lbs at 3,400 - 3,800 rpm. And the X6 is supposed to be about 150 lbs lighter than the X5.
BMW's published X6 acceleration is 0 - 60 in 5.3 seconds, a full 1.2 seconds faster than the 4.8i. Real world acceleration probably will be a little quicker given that BMW's published numbers are usually conservative.
If my experience with the turbo V-6 is any indication, acceleration will be effortless and deceptively smooth. Maximum power will be available as soon as you press the pedal and will be applied to a lighter vehicle in an RPM range where people actually drive (vs running a V8 at 4,500 rpm.) It will be the type of vehicle that hits 100 mph on the on-ramp before you realize what's happening.
This turbo V-8 also will be used in the new 7 series, which should be lighter than the X5/X6 and won't have the added weight of AWD. That should be very interesting.
Thats true 4.8 x5 has done 0 to 60 in 7+ and what they wrote were 6.5sec
By all the engine calculations that you have done will the x6 be more comfortable better ride quality better handling will be there surely.
350hp and the rpm is?
The X4, if it is real, would probably be "perfect."
My wife just ordered her second X3 and even tho the upgrades from '05 to '08 are moderate, the new X3 is a very nice way to cross country or go to the grocery.
She almost for a half a second went with an Acadia.
Whew! Dodged that one.
The thing is, the new X6 is, in pictures at least, soooo darned good looking.
Yes off course thats why i think in every way x5 is the better car but exceptional if you want the looks style some think that looks different and sporty
I think it will have a geat look compare to the x5
If any1 else has also just got their new x6 congrats and plz share your experience.
I have read before this car is similar to the infiniti fx but its totally different IMO.
It looks so much better in person than the pictures.
I didn't see it on road only i saw it detail by detail standing.
Never seen anything like it before never liked a car like this never before in my life.
By the way they don't call this SAV anymore its SAC
Sadly i will not be able to get 1 anytime soon
BMW's Market Target For The X-6: 6 Series and X-5 drivers.
The X-6 is built on the X-5 platform, with a similar interior.
Main Difference: The rear seat head room is compromised with the sharp-sloping roof line, thus being called a "sports activity coupe". If a 3rd row seat, and reduced cargo space (again because of the roof line) are not an issue, than this could be the car for you. The I-Drive software is from the 6 Series' edition (and also the latest X-5 models), which is the most preferred edition, because of its simplicity, compared to other BMW models.
OPINION: I see this BMW model competing mainly with the Audi A-3 and Infiniti FX. Yet, it's totally BMW and without a doubt, going to be a head-turner.
SUGGESTION: As a new model, lease and finance rates will most likely be uncompetitive, as well as the first run being potentially problematic (as the case with most first-run BMW's). Wait until both engines have had their first year runs, and test-drive an X-6 to make sure the interior space is not going to be an issue.
Being problematic that really makes me nervous which i am getting use to hearing abt bmw now and then.
The front space isn't much different than the x5 but back will certainly be not as comfy as a x5 and with only 2 seats less head room.
First Drive: 2008 BMW X6 xDrive 50i
So, you GIVE UP utility and GIVE UP handling and gas mileage.
Who's the target buyer?
Well i guess then some1 paid. 1 of my near neighbors got a brand new shiny bmw x6 35i in silver.
When i saw it I just wanted to stand and keep looking for a while :blush:
I am not sure but since i didn't see his merc S class I think he traded in.
When i use to see the picture of the x6 it felt it would be like infiniti fx but in real its a lot different but definitely not for every1.
I think family should stick with the x5.
I just sold my BMW and it was first year model. I will NEVER buy a BMW first year model again. Too many problems and the value went down, down, and down. I lost so much money b/c of getting a bad rap. ....it's such a shame!
That's exactly what I heard too, production is slow either intentionally or they're having technical issues. Dealers are saying that supply will be very "limited". what a load of blatant hype. I'm not crazy about the price either. I could get a lot more car for $55-65K.
Which class was it?
The good: A very good turning radius, great breaks, nice sport seats, very nice fit and finish.
The Bad: I'm not so sure about the styling, but that could just be me.
If I optioned the six cylinder the way I want it, it would list around 63k.
The eight would be around 74k.
The dealer said the eight is scheduled to be out in October.
So will you be getting the x6?
How good is the acceleration 0 to 60 in your opinion?
I am beginning to think how good is the v8 than the inline 6 cylinder just faster :confuse:
From what i heard the v8 will be available in july !!!
What was the 0 to 60 ?
So I assume you won't be getting this car then what are your other choices?
I think the new infiniti fx50 will be nice
There is always a cayenne which people say is ugly :confuse:
It's too much wow at first and blah after.
Really that doesn't sound nice abt this SAC.
