Mazda CX-9 Airbag Location?
Precisely where will the front passenger airbag deploy? I'm adding some accessories to the dash of my CX-9, and (obviously) want to avoid the possibility of the airbag launching them.
From the bottom, there is the glove compartment. Above that is a big, blank panel. Above that is a seam, and a panel labeled "SRS AIRBAG."
Does it deploy through that upper SRS AIRBAG panel?
PS - It's refreshing to find a forum where people actually help each other. No flames, no snarky comments!
Anybody have any tips of where to tap switched +12VDC?
I know where the 12V constant and 12V switch tap-ins are. Read either one of the PDF instructions listed in the starting post of the thread.
http://www.mazdas247.com/forum/showthread.php?t=123669277
- 12V constant: homelink uses 12V constant
- 12V switch: autodimming uses 12V ignition
They are inside the kick panel.
the passenger-side airbag is on top side of the glove compartment.
When it deploys, the top side plastic trim will tear open and the airbag will expand from the borken seam.
Don't put anything on top of it (as expected).
I ended up tapping a big, fat switched +12VDC line (black/ white stripe) at the back of the fuse box. It's a big (15A?) circuit that feeds the accessory outlet on the front dash. Plenty of power for these little accessories.
Thanks again for the assistance. This board is great! :shades:
