Mitsubishi Outlander Audio Sirius Bluetooth
medellinrob
Member Posts: 7
I'm close to buying an outlander XLS.
I'm in love with the 9 speaker rockford system sound and what people think about it.
I plan to install a parrot mk6100 with a2dp audrio, in order to play on thar system music from my cellphone....
Will I take advantage of the System? Or Does my mobile phone or parrot mk6100 will be a bottleneck?
Do I explain myself?
Question 2: I hear heavy metal and power metal, and I dislike rap and other busic that makes the speakers vibrate BROOOM.... BROOOM... Wirh my music I won't have a vibratin car, right?
Regards..
Regards..
Have fun
Ron
Thanks in advance for any help anyone can offer.
If you can't get Ch 184, you don't have it. If you can receive it you should be able to call and sign up.
Sorry.
Thanks for the comments and the help though!
I'm looking for an existing path through the firewall to power an amateur radio in my 2007 Outlander. For best RF performance, I need a direct connection to the battery.
Mark, KI6KQD
I noticed a upsetting (very high frequency) noise in mp3 cd playback. The noise will be perceptible for 5 seconds at the beginning of any song and then, every 8 seconds the noise will be audible for 1 second.
I think this is due to the CD player electric motor starting to fill the anti-skip buffer of the playback system.
I've aks the dealer, they don't know about it. At the dealer, I tried an other Ottie radio and same problem....I wonder if anyone else has the same issue???
ty
It's much better in that regard than an aftermarket system.
You can adjust the subwoofer output, also.
Have you had any success in resolving this problem?
My LS 2008 has inbuilt bluetooth capability.
This means I can make/receive calls
which are played via the inbuilt stereo system.
However, my phone also has an mp3 player.
Is it possible to play music from my phone
so it comes out on the stereo system via
the bluetooth connection. I know I can plug it
into the jacks at the back of the center console.
Regards.
has anyone complained.
But I've only being using it for a few days.
I bought a used Mitsubishi outlander "from Feb 2008", when trying to enable Bluetooth I got the message that "Bluetooth is locked and I have to enter the password". Unfortunately the dealer did not know the code and don't know how to reset it.
I tried the 0000, 1111 and 9999 but does not work.
Is there a way to reset the Bluetooth code, any help would be very much appreciated.
Thanks in advance,
Erik
Thks,
Erik
- Press and hold the hang up button for 2 seconds (do this 3 times total back-to-back) - the whole process should take more than 10 seconds
- Press the speak button to see if it asks you for the password - if not, problem solved.
It completely resets the bluetooth module back to factory settings. It should work. I had the same problem.
Wait 1 second between each button push. So it should be
Push end call button for two seconds
wait 1 second
repeat two more times
when you say ignition button to on "what is this !" it's not the speak Bluetooth
button?
thks
Just kidding. Yeah, time for warranty. Very weird.
My iPhone is happy and the woman talking to him also
hands free and see Tracfone now has a bluetooth phone available. (I don't live on the phone)
2010 models have dual-mics in the headliner; I'm not sure about prior years.
BlueTooth has profiles for different functions so it's possible your Outlander supports BT phone profile but not BT audio streaming. Basic profile info at http://en.wikipedia.org/wiki/Bluetooth_profile
It isn't super detailed but there is a little info at http://www.mitsubishicars.com/MMNA/jsp/owners-site/technology-features.do
Beyond that I'm not sure so I'd suggest doing an RTFM or calling Mitsu's customer service number: 1-888-MITSU2010 (1-888-648-7820). Some references I saw from a quick search showed that dealers should be able to reset the BT module.
The forum software must've glitched as I was viewing the threads using the "Read new posts" option.
But just think of all the Bing/Google/Yahoo searchers you've helped. :shades:
