Welcome to the Edmunds forums! Sign-in process in our forums has changed. Click here to learn more.
2008 and Later Ford Taurus / Mercury Sable Maintenance and Repair Forum
2
  • Not to jump the gun, but what are some of the better used car buying sites.
  • Bought a 2008 used, very low mileage FWD Taurus about a month ago. I immediately noticed that when I start the car in the morning the engine is rough for several minutes. The engine sounds like it misses and the car even vibrates a little. I took it in to have it checked and naturally they said they didn't hear anything. The other thing that concerns me and may be connected is that I'm only getting 18-19 MPG for combined highway and around town driving. I got 18.4 MPG driving a 180 mi stretch of freeway. The car has about 9K miles. Will gas mileage improve or is it possible that the gas additives in Ca. are contributing to the problem. This will be my last Ford if the Ford dealer sold me the car letting me think I'd be getting 28 MPG.
  • I believe you may have a problem. I get 28 or better mpg on the highway (at approx 70 mph), and 18 or 19 around town (but not center city driving) with my 2008 Sable. I have no rough idling at start up. Take it back to your dealer or to another one.
  • thegraduatethegraduate Posts: 9,731
    My folks average 26 MPG when they travel to and from the gulf coast. They average closer to 80 MPH though. In mixed driving, they end up around 23-24. Few stoplights however.
  • keithm1keithm1 Posts: 22
    How does one remove one of the fog lights to replace bulb? Manual says to turn clockwise..when bulb comes out..disconnect connector & replace bulb. I find that there is a "phlange" that seems to prevent you from turning bulb to remove from socket. Anyone have any ideas to get around this? :confuse:
  • mek0123mek0123 Posts: 33
    My 2001 Dodge Grand Caravan ES has auto climate control. In the winter, (like now),if I have it on auto setting, it does a timed countdown and starts anywhere from 2min to 3 min or so. During the countdown, I have absolutely no air flow at all. Once it gets to zero, the blower automatically makes up for lost time blowing at a very high speed until the cabin starts to reach the preset temperature. Therefore, your unit is probably operating as designed.
  • merlinhmerlinh Posts: 1
    I had similar problem with my Lincoln LS. It started to make a rubbing noise when the steering wheel was turned. It was ball joints, needing to be replaced. On the LS it was a $900 job.
  • ronsmith38ronsmith38 Posts: 228
    I see where one can add the Sync feature as an accessory to the 2009 Taurus and Sable, but they don't show it for the 2008 models. I wonder why this is, since it was available as a feature (or standard) on 2008 models?
  • pjoannamopjoannamo Posts: 5
    I saw your post and had the exact same question.. I too bought a 2008 Sable Premier with the 3.5L and my gas mileage is exactly what yours is.. Did you get a resolution to this and what did the dealer do?
    Sincere Regards,
    Pete..
    Just bought a 2008 Sable Premier with 18K miles. Took our first ride along the florida east coast cruising at 45 MPH and only got at best 17.5 MPG with hardly little to no stops for several miles. Filled up another tank of gas and drove strictly the highway at 80 MPH for 55 miles and got 18.2 MPG. I bought the car with the understanding that the MPG rating was 19/28. Has anyone else experienced this problem and if so what did the dealer do if anything.
  • drew70301drew70301 Posts: 5
    I have a 2009 Sable Premier FWD with 4,500 miles. I consistently get a display reading of 28 to 30 MPG at 65 or 70 mph. At 45 to 50 mph, I get a display of 30 to 32 MPG. THis is with the AC on.
    I have no idea what is causing your porblem. Check to be sure you don't have the OverDrive off or that you are not using the L on the gear selector. Are the tires properly inflated. Is the parking brake completely off? I know these are all obvious questions. Don't mean to offend.
    Tires are Pirelli's inflated to 35 PSI.. checked them all before the trip... I thought the Overtdrive was set to off but it wasn't.. parking brake is ok.. I just put in some fuel injector cleaner hoping that this does it... I called the dealer where I bought it.. and they offer no assistance... I'll have to see if this is covered on the factory warranty.. thanks for the obvious..
    If you are going by the MPG on the display, don't forget to reset it at appropriate times. Also, you will need to manually calculate the MPG based on fuel use and miles driven between fillups (the old fashion way). This calculation will be the most accurate determination, but will have combined city/hwy driving, unless of course you drive only on the hwy between fillups.
    Another obvious statement. Your milage will GREATLY depend on HOW you drive. Lots of fast starts eat up lots of gas. So, take this into consideration. But if you reset your MPG display once at a constant speed on level ground, and wait a few min to get a decent average, you should get something close to what i get. Note that strong head or tail winds can make a difference too.
    Thanks for the advice.. my problem was not resetting the AVE MPG setting on the display. You were right again by calculating the MPG the old fashion way.. I did receive a better result.. about 1.5 MPG better.
    Do you know anything about ethenol? How much of a decrease in fuel economy can we expect from the manufactures estimated MPG rating (assuming we're driving with normal habits of course)? Or, does the manufacturer's MPG rating reflect that of using ethanol?
    Don't know much about ethanol in fuel. There are lots of information available on the internet, easily found through a google search. I remember looking it up some time ago. What I do remember is that 5 or 10% ethanol will make a small difference in MPG. Of course, E85 makes LOTS of difference. Do a google and you will find some charts of how this affects MPG.
    Glad you feel better about your milage.
  • I have a 2009 Mercury Sable Premier FWD with 18" Pirelli' tires and app 4ooo miles and my car makes a "clunk" noise when going over bumps at slow speed. I have taken it back to a local Ford Dealer and they replaced both front struts and also the strut mounts and said that the sound is gone. Obviously they are deaf! So I found this forum and noticed that this seems to be a recurring problem dating all the way back to the late 1980's with Taurus's & Sable's.
    I have seen posts for pre-2000 year cars but is anybody with a more recent model year also experiencing the dreaded "CLUNK" noise? And if so, has the noise been fixed? Right now my options are to live with the noise or to go to the dealer and suggest they start replacing parts (sway bar/front stabilizer connecting links and/or Control arm bushings) per previous postings to see if the problem gets fixed for real this time. Any thoughts would be welcome, Thanks!
  • I have a 2008 Sable that had the same problem when I test drove it. However, this problem you're referring to has nothing to do with the problem you're describing in earlier models. The pre-2000 Mercury/Lincoln vehicles had a clunking noise in the front end that whenever you mad a hard turn, you would hear the clunking sound. They re-designed the front end in the larger vechicle to stop this.. But.. for the Mercury Sable 2008 2009, there is something in the left front kickplate that the dealer replaced and said it's a recurring problem in this style vehicle.. I purchased the vechicle at Holeman Lincoln Mercury Dealer in Hollywood Florida if you want to give them a call. The mechanic who worked on it knew a lot about this problem.
    Hope this helped.
  • EXCELLENT! Thanks for the info. And it's a small world - I had the struts replaced at Holman Lincoln Mercury Dealer in Maple Shade, NJ, which is part of the Holman Auto Group, which owns both car dealers! So I will be contacting my dealer today with the info and I'm sure that they will get in touch with your dealer to get the lowdown on the repair and I will follow-up with a new post when the repair is complete. THANKS AGAIN!
  • Pjoannamo, Would you believe it? The Holman Dealer in NJ won't contact their Florida Dealer to find out info on what you mentioned because they are saying they don't think it's the same problem. Hello - same car model and same general problem description? So I was wondering if you wouldn't mind letting us know the name of the person in the service dept that served you so we could call him/her. Thanks In Advance.
  • I have a 2008 Ford Taurus that squeeks loudly going slowly over speed bumps or any bumps for taht matter. When I take it in for servicing I'll bring it to their attention but I'm sure they'll say it's normal even though it shouldn't be normal. Susan
    My folks have a 2008 Taurus that squeaked over speed bumps after a few thousand miles. One trip to the dealer solved the common problem.
    Have a little faith!
  • kd7oqckd7oqc Posts: 8
    What did the dealer do to solve the problem?
  • The following TSB fixed my 2008 Sable. (I have a pdf file which has a diagram, but I don't know how to include it here.)
    TSB
    07-26-8 FRONT STRUT NOISE - BUILT BEFORE 10/19/2007
    Publication Date: December 21, 2007
    FORD: 2008 Taurus X, Taurus
    MERCURY: 2008 Sable
    This article supersedes TSB 07-19-3 to update the Service Procedure and production fix date.
    ISSUE:
    Some 2008 Taurus, Taurus X and Sable vehicles built on or before 10/19/2007, may exhibit a popping/rubbing/grunting/squeaking or creaking type noise from the front strut mount. Typically, the noise is observed in the front outboard wheel while turning. This noise may be caused by the jounce bumper rubbing against the strut rod, or the dust boot rubbing against the strut mount cup.
    ACTION:
    Follow the Service Procedure steps to correct the condition.
    SERVICE PROCEDURE
    Raise the vehicle as described in Workshop Manual, Section 100-02.
    Reach through the spring and pull the strut dust cover and jounce bumper assembly straight down, out of the strut bearing mount.
    Apply Motorcraft Silicone Brake Caliper Grease and Dielectric Compound: (Figure 1)
    To the entire length of the chromed strut rod above the jounce bumper and 360° around the rod.
    To the top and sides of the uppermost part of the dust boot.
    Figure 1 - Article 07-26-8
    Slide the dust cover upward into its original location on the strut.
    Repeat the procedure on the other side of the vehicle.
    Lower the vehicle.
    PART NUMBER PART NAME
    XG-3-A Motorcraft® Silicone Brake Caliper Grease and Dielectric Compound
    ronsmith38's post answers it. They lubricated some things using that TSB and it is quiet as a mouse now. Returned 26 MPG on a short trip from Gulf Shores, AL to Biloxi, MS this weekend at 75-80 MPH with three of us on board.
  • Anyone have any info on what a 30,000 mile service should consist of and cost for a 2008 Taurus? Took mine in today, and I'll be $579 lighter by the time I get the car back. I don't feel terrible about it since this is the first time I've had to take it in since getting the very early glitches taken care of (squeeky struts, fading trip computer LEDs). Still - I always feel like I'm just offering up my checkbook and asking them to take whatever they want when I go for a scheduled service - I don't have a good feel for what is reasonable. Otherwise, I'm loving this car - so glad I didn't go with an import.
  • I look at the maintenance section of the owners manual and only have items done that are required there. The dealers like to do other unnecessary things.
  • drewhwdrewhw Posts: 2
    Need to change transmission fluid. When I get under the car, the trans. plug does not look odvious as the oil plug does. Actually it looks as if there are two plugs, one lower and one a bit higher in another area of the transmission. can anyone give me an idea where the plug may be located? Thanks!
  • I have an 08 Mercury Sable with 40K miles. I have recently begun to hear a scrubbing/swishing noise at low speeds. It is inaudible a speed because road noise drowns it out. The noise is a rapidly recurring at low speed and most noticeable when making a right turn thereby loading the left wheel from whence the noise comes. Anyone had this experience, if so, what's the fix.
  • bfamilybfamily Posts: 15
    Mine had a similar noise but also a resonance at speeds between 70 and 75 mph. Ended up being the left front wheel bearing.
  • I bought an 08 Sable new. Gas mileage is around 21 mpg more or less depending on the ratio of city/highway driving. The computer readout re: mpg bears no relationship to reality. It's a great car in many ways but gas mileage is not it's recommending quality.
2
