Toyota RAV4 Wind Noise
I have loud wind noise when the rear windows are rolled down. Its like a decompression and recompression of my ears. Is this normal. Its a new Rav4 08.
I'm not sure how to explain it but you can not roll down the windows with out hearing the noise.
Its a fast pu pu pu pu pu pu pu pu sound.
This happens when i start hitting 40 miles an hour on the freeway.
Is this normal?
Is this normal?
Absolutely,...SOP..!
Think of blowing a whistle..
When you roll down that window "at speed" it's like blowing across the top of a coke bottle, except at 40 MPH the airflow across the bottle top is much higher and the back of your car has a LOT more volume, so the "whistle" frequency is really LOW, in the range of a helicopter blade.
Cracking a front window as little as 1/2" will usually alleviate the "noise".
If it were infrasonic then you wouldn't hear it.
SUVs and Smart Shopper
Then it could be infrasonic....
Do we actually hear it or do we really only feel the air pressure waves...??
That would be a good bet. It's quite easy to get a flute to produce harmonics when you up the amplitude a bit. And if the amplitude of the oscillation in the RAV4 is great enough to feel then you're probably above the threshold to produce harmonics.
That might be, predominantly, what we "hear".
This wind sound noise is normal to most off all automobiles car . This is an aerodynamic issue that can not been fix by the car manufacturers . The only thing you can do is open the front windows left and right just a little while the back windows are fully opened , that will eliminate that helicopter low sound.
I had other car type with the same issue.
Maybe the defletors window installed will eliminated that noise but personaly I dont like these deflectors.
I just Buy 2 weeks ago my second new Rav4 2012 Sport V6 Letther option etc .. FANTASTIC CAR !! :shades:
