Have you recently switched from a luxury sedan to a luxury SUV? A reporter would like to talk to you; please reach out to [email protected] by 7/25 for more details.
Toyota RAV4 Wind Noise
2008car2008car Posts: 29
I have loud wind noise when the rear windows are rolled down. Its like a decompression and recompression of my ears. Is this normal. Its a new Rav4 08.
I'm not sure how to explain it but you can not roll down the windows with out hearing the noise.
Its a fast pu pu pu pu pu pu pu pu sound.
This happens when i start hitting 40 miles an hour on the freeway.
Is this normal?
  • wwestwwest Posts: 10,706
    "Is this normal?"
    Absolutely,...SOP..!
    Think of blowing a whistle..
    When you roll down that window "at speed" it's like blowing across the top of a coke bottle, except at 40 MPH the airflow across the bottle top is much higher and the back of your car has a LOT more volume, so the "whistle" frequency is really LOW, in the range of a helicopter blade.
    Cracking a front window as little as 1/2" will usually alleviate the "noise".
  • sdc2sdc2 Posts: 780
    Yep...it is basically an infrasonic whistle. The RAV does it pretty bad, but I have heard it in many other vehicles as well.
  • tidestertidester Posts: 10,059
    If it were infrasonic then you wouldn't hear it. :)
    SUVs and Smart Shopper
    Hmmm...
    Then it could be infrasonic....
    Do we actually hear it or do we really only feel the air pressure waves...??
    The beat of this effect is less than 10 cycles per second...it is generally assumed that people cannot "hear" sounds below 20 cps and based on my audio experience even this is optimistic. But you can definitely feel it in your head and ribcage. There is a slight bit of noise associated with each beat, I am unsure if these would be considered harmonics, or more likely just produced by turbulence around the window edge (a more perfect whistle would have sharper edges at the opening).
    That would be a good bet. It's quite easy to get a flute to produce harmonics when you up the amplitude a bit. And if the amplitude of the oscillation in the RAV4 is great enough to feel then you're probably above the threshold to produce harmonics.
    But then there is the "vibrations" effect the air pressure waves cause on the interior materials and surfaces.
    That might be, predominantly, what we "hear".
    Possibly but I don't think we've actually established whether the "sound" is infrasonic and more input from the OP would be helpful. It could just be audible low frequency sound. In any case, it's probably just the ubiquitous "helicopter" effect with sound being produces with pressure changes occurring at the window opening.
  • I just bought a rav 4 2012 and am very unhappy with the same noise. Dealer says its normal, but to me it is unacceptable. Taking the car back.
  • fredy3fredy3 Posts: 27
    Good Day
    This wind sound noise is normal to most off all automobiles car . This is an aerodynamic issue that can not been fix by the car manufacturers . The only thing you can do is open the front windows left and right just a little while the back windows are fully opened , that will eliminate that helicopter low sound.
    I had other car type with the same issue.
    Maybe the defletors window installed will eliminated that noise but personaly I dont like these deflectors.
    I just Buy 2 weeks ago my second new Rav4 2012 Sport V6 Letther option etc .. FANTASTIC CAR !! :shades:
  • Yes, this is normal. I also have a 2008 Rav 4. If you roll down the front window just a little, this will alleviate what you are hearing. I had this happen with my previous car as well.
