Windshield Wind Noise "Honking" Specific to '08 GC & T&C
I've not been on this forum for long, and came here to find information on the "honking noise" appearing to come from the dashboard, when the vehicle is at 70 mph +, and more so when driving through a crosswind. It can, at times, sound as though there are multiple points of origin for the noise. In the case of my vehicle, it has been intermittent, sometimes lasting for several minutes and then stopping, and not recurring for hours, even if the driving conditions remain the same.
While I did find information in other threads within the forum, the threads seem to have diverted into other areas of interest, which for others with this specific issue, will not be relative. I'm hopeing a seperate post will be more effective. (Moderator, your welcome to move my previous replies to this post).
On Wednesday, July 3rd, I spoke to the Chrysler engineer that worked this issue. The cause is the gap and/or flap of rubber moulding between the "A-pillars" and each side of the windshield. The fix, as you may read in other posts, is an application of silicon into that gap, and evidently under the thinner flap of the moulding material that lays against the pillar.
After my conversation with Chrysler, I forwarded an email to the engineer regarding my experiences with various "5-Star" dealers, trying to verify this issue and get a technical service bulletin reference. Until I heard from Chrysler, I had only received inconsistent and incomplete information; some service writers couldn't find any information on "wind noise" with the van......this in the face of two other national issues; roof rack and sunroof.
I'm waiting to hear from the engineer at Chrysler with a firm Tech Service Bulletin number, so that I can share this with others in our corporation who are driving the same vehicle, and have had similar difficulties getting a resolution.
Al in SoCal
Al in SoCal
Please keep this thread up to date with any findings you get. Can you please direct me to these other threads you mention that refer to this issue?
JK
Does anyone know for sure?
I have an '08 GC and our whistling noise was "diagnosed" as #1 passenger side rear mirror, and roof racks and then the seal around the windshield. Service department order new windshield and gasket. This seems to have fixed the problem. I leave for Myrtle Beach (from Maryland) in a couple of weeks so it will be a great test then. I will be taking some tape with me just in case I need a quick fix.
which mentions a specific bulletin: "honking sound windshield issue, silicon repair." bulletin #PT9001890.
After that message though, there are still a few pages of people discussing how difficult it is to get the dealer to acknowledge the issue. Has anyone mentioned this bulletin to their dealer?
As for the windshield noise fix. We're on our second day of high speed testing after I siliconed the sides of the windshield. I didn't bother to go under the flap of the rubber moulding, but just ran a bead of clear silicon in the major gap between the A-pillar and the visible rubber moulding. I then used a water-wet paper towel to wipe the silicon down and into the gap. And very important; I used 3M painter's low-tack blue tape to mask off the rubber moulding and pillar, such that the silicon would be limited to traveling into the gap and not onto the auto body or moulding.
I'm still waiting for the engineer to answer my email with a specific bulletin. But if you contact any dealership service department, just tell them that they should find at least 3 bulletins on wind noise:
1. Luggage rack...improper installation...needs to be repositioned
2. Sunroof...???...???
and
3. Windshield...silicon seal between A-pillar and rubber moulding, under moulding flap.
Even without the bulletin number, you should be able to find a service writer somewhere that knows how to search his tech service bulletin pages by the keywords; wind noise windshield honking whistling, etc.
Good luck, Al
Rob
Your dealer is correct. The number I was given by a dealer a few weeks back was boogus. But the repair instructions that I got from the Chrysler engineer was all I needed. He still hasn't replied to my email with the tech service bulletin number. I'm going to send another email and call him again.......one more time. As far as I'm concerned, I fixed the issued a couple weeks back as mentioned in one of my posts. I just used a clear GE exterior grade silicon. I masked off the metal on both sides of the gap, and ran a bead of the silicon down both sides of the windshield, then finished it with a pass of my gloved finger. It was neat and best of all, immediately stopped this issue. My concern was for our other drivers in the corporation. The less I have to deal with a dealership, the better.
Could this be the windshield noise you are talking about?
Thank you. It only sounds sometimes and not others but always at 55MPH or above.
Ironically, my right front brake caliper started "grinding" yesterday, 13k miles so far, and now I'm torn between going to the dealer under warranty or taking the van to my local Firestone where I can watch them work and get it done quickly while I wait.
Good luck, Al
That warranty is so good and free that I'd get all work done at the dealer and then if something is wrong with the work--you won't be thrown back & forth between people who worked on your car!
Thanks for your help--PS--on a 120mile trip expressway we're getting 27.8mpg and around town about 19mpg--great news for us!
When I was getting the noise, I found it would go away for a couple/few minutes if I pumped washer fluid on the windshield. The fluid must have filled up the same gap.
To find the affected area: Put your finger on any part of the windshield and work left or right. At the edge of the windshield you'll encounter approx 1/2 inch rubber weather seal, then a 1/8th inch gap, then the painted metal surface of the A pillar. I applied tape over this gap from base of the windshield to the top (about 2 feet length) on both A pillars.
Tape worked as a temp fix / troubleshooting aid. The silicone sealant should work as a permanent fix. It seems like a filler of some kind, like the thin rubber tube that holds a window screen in it's frame, could work as well. Gotta see what Dodge has come up with.
