For the last year our air conditioner (on both a/c and heat) makes these horrendous loud noises about every 30 minutes to an hour when the a/c or heat is on. I have to shut the air conditioner off and then turn it back on to get the noise to stop. By loud...it sounds like a train is bearing down on you in the car...
We took it into our honda dealer and they had a hard time recreating the sound (because they weren't driving it around for 1/2 hour.) They finally recreated it once about the third time I took it in. They replaced the air condenser, but that didn't fix the problem.
Any ideas? Could it be a bad bearing?
"Your compressor failed for a reason. The number 1 reason is contamination in the system. Cleaning out this contamination is crucial to ensuring that the new compressor is not also contaminated. Always flush and evacuate before changing parts. Always use A/C system flush solvent. If it is not perfectly clean after the flush and vacuum, we recommend re-flushing the system."
My Atlanta Honda dealer botched my A/C system repair by initially just installing a new compressor and running the system to note poor performance. Only then did they inspect the accumulator/drier (replacement of this part is REQUIRED by every compressor manufacturer as part of the warranty) and noted it was leaking desiccant balls and other black junk into the system. THEN they decided to flush only the evaporator line and replace the clogged dryer and also the contaminated condensor (the A/C radiator at the front of the car, often difficult to flush). This is noted right on my invoice! The invoice doesn't mention cleaning or replacing the expansion valve nor purging the other line - things any half-trained A/C technician would have done. Obviously, my new compressor now has it's oil flooded with seven years of accumulated black crud. So I just paid $1,800 for a brand new compressor which WILL fail prematurely.
I have a case open with Honda corporate to see what they can do given that the repair ddn't follow the Honda's - or anyone's - service procedures. You have to watch your dealer closely to ensure they perform the A/C repair correctly. The warranty on the repair will be only 90-days labor / 12 -months parts so, if the new compressor fails again within a year, you get to hassle with them all over again on the labor. After a year, you're just out another $1,500-$1,800.
Bottom line: Honda said repairing a contaminated A/C system just by replacing one part at a time was “proper”. The attempted over-charges and commission wrangling are solely between me and the dealership. Honda suggested I contact the dealership Service Manager again to see if he can explain what they had previously refused to explain. In a word, Honda offered me NOTHING.
If you’re looking for Honda dealer service in downtown Atlanta, you’d be wise to go far North (Woodstock, Georgia) or far South (Morrow, Georgia) instead. Even then, ask in advance to insure that your Service Advisor will be working the next day too in case your car needs to stay overnight. If anyone quotes you a price over the phone, get their full name to avoid hassles over service prices and commissions. Better yet, find a small, local shop who works off their reputation and repeat customers.
I have a 2011 Honda Pilot with 9,000 miles on it. In the last few months I've noticed that at stop lights (i.e., in gear but brake applied) it will lurch forward. I thought this was just part of the engine revving to compensate for A/C on a hot day, but it also happens when the A/C is off. Anyone else experiencing this?
I am planning to change the cabin air filter as I expect that can only help, but was wondering if anyone had any ideas as to how to make it blow warm air again or what the scope of the problem might be? Any help or ideas would be welcomed.
First, we noticed that the a/c would cool when the temp was turned all the way down (like 60 degrees) but if we turned it up just a few degrees it'd go strait to full heat.
Then, the rear a/c stopped working all together, no blower or anything. This summer I had cleaned the vent and replaced the $80 resistor on the drivers side of the center console and it worked great.
Now, the dash vents just blow ambient air. We hear a loud hissing from behind the passenger side of the dash from time to time but nothing consistent.
This sound familiar? Any ideas where to start?
I just changed my AC Filter since I have never changed it before ( it was not so bad ) however, I noticed when I looked through the filter case compartment that both pipes where the expansion valve is attached were extremely "sweaty" and dripping few dropps of water every 10- 15 sec. Also the tube that continues through the firewall was also "sweating a lot " as well as the whole low pressure tube .
The Compressor engaged with no problem , both fans are working. compressr clutch engages with no problem but it seems that doesnt desengages, it is ON all the time ( im assuming because is trying to get the interior of the car cold but it doesn happen, inside the car is not cold as should be ) .
I re-charged with more refirgerant becasue it was a little below where it should be and i used the UV dye one but After i recharged i didnt found any leak. Now same signs, ac not cooling enough and a lot of sweaty pipes and lots of dripping through the draining hoses. Please help, any ideas?
