Infiniti G35 & iPhone 3G
I have the new 3G iPhone and the bluetooth works fine. However, when I hook up the iPhone to the cable in the center console where my iPod used to be, the message on the iPhone says this cable can not charge the iPhone and do I want to change the mode to Airplane mode so that the phone doesn't work. While the iTunes library shows up on the navigation screen, I can't control the itunes with the iPhone while it is hooked up with the cable.
Does anyone know if I need a new cable or if it just doesn't work with the new 3G phone?
My '08 G35 charges my old-style video iPod just fine - and plays great of course - but I haven't checked it with the 3G iPhone yet. I did pickup an iPhone a few days ago and can conform what you saw - it says it cannot charge - but hadn't loaded any tunes yet. I will test tomorrow music playing tomorrow.
I would think Infiniti could come out with a new cable that uses the "correct" power-supplying pins. That change would probably fix the not-playing issue since it sounds like the iPhone is stopping the playing when hooked to the now obsolete cable. Whether Infiniti will do this or not remains to be seen.
kc
kc
Jeff
http://www.scosche.com/products/sfID1/210/sfID2/318/productID/1667.
It costs about $30.
-DAB">link title
I used this for my Infiniti G35.I have a plug that usually charges and puts all the info on the G35's LCD and I control it via the cars dash. When i got a new 5th Generation IPOD, I would still be able to control it via the G35's system but it would not charge and a message on the IPOD's LCD warned this. I found out that it is because older IPOD's charge 12v and newer 5volts. So if you IPHONE says 5v on the back, which it might. This is your solution...
