How to get a more comfortable ride with a GMC Yukon
Hi! I have owned a 2001 Yukon for a few months and it has a pretty choppy ride. The vehicle has 49,000 miles. What can I do to get a smoother, more comfortable ride?
Also, the drivers seat (leather) isn't comfortable. Any suggestions? Thanks, Dan
SUVs and Smart Shopper
Also my Yukon doesn't have the self leveling system.
Has anyone installed Sensatrack shock absorbers to soften the ride?
Thanks for the replies!
http://www.edelbrock.com/automotive_new/mc/shocks/car.shtml
Does anybody know how solve this problem?
Thank you for the info,
How does the vacuum gauge BTW work?
A vacuum gauge can be used to detect low/unstable vacuum pressure in the system, which are indications of a leak (i.e. cracked vacuum hose, canister, or for some models even an improperly seated PCV valve and etc). I would think that you may be able to barrow a vacuum gauge at your local Auto Parts store (e.g. Advanced Auto, Auto Zone, and etc.; I have even came across them at Mijer, Sears and Wal-Mart stores if you wish to buy one), each gauge should come with description/recommendation on how and where to hook it up, and how to interpret the reading and response on a gauge (not all gauges act/respond the same way; but should be similar). This, in my opinion is an inexpensive way to narrow out other possibilities that can cause engine shake before getting to the catalytic converter. Best Wish!
Just as FYI:
http://www.actron.com/product_detail.php?pid=16176
idahodoug, "Toyota Land Cruiser" #2375, 10 Feb 2003 6:24 pm
When I took it to the local GM dealer they told me that the extended warranty did not cover broken bolts. Had I ignored it until the manifold was leaking, they would have covered it.
Why would the GM 5 yr, 100,000 mile drive train warranty not cover this item, in lieu of my non-performing separate warranty? They quoted me a price of $290.00 to repair.
Has anyone else had this kind of problem with exhaust bolts breaking? The service writer did not seem surprised and even guessed that it was the front bolt before even looking.
I had a Dodge Durango before, which had a great ride, so I dont know if its just me or is there something more i should be looking for -
Any suggestions would be appreciated.
Q1. Does your Yukon equipped with 3rd row seats; if YES, are the seats removed?
Q2. Does your Yukon still have its spare tire mounted under the chassis?
Without the seats and spare, the lack of their weight can make some people feeling the ride "rough" (Choppy)...
Other than the above, I would take a look to make sure the bushings are in good shape (not dried-up/cracked) and securely mounted... (i.e. Shocks, sway bars, exhaust system, engine mount?? and etc.)...
