Dodge Stratus Maintenance and Repair
in Dodge
The car had a dead battery for about 3 months. Before the battery was drained my leaving interior light on. The car had been driven 3 times a week. tThe battery was about 6yrs old, wouldnt take a charge enought to start. I recently replaced the battery, but while the engine turns over, spark plugs fire (checked with a timing light) but vehicle will not start. Is there anything I need to reset and how?
Phast
It is running like a top........... NO LEAKS....
My problem happened sporadically, and not all the time either. but I did notice that it happened more often when the outside temp was hot, and I had been driving my car for awhile. Even if I parked it and let it "cool down" some, it still would not kick over unless I waited about another 30 minutes.
the CPS unit is notorious for going out after about 150k miles. I have a V6 4.0L engine, and it is a hard working engine, but computer parts will wear out eventually and that means no kicking over....just a thought........
carpartswholesale.com/catalog you will find it here..Hope that helps..
So what should the problem is.
Bought this car and on the way home it got hot and would not restart. I have found water in the oil and oil in one of the cylinders. I have pulled the head and might see signs of a head gasket leak, but minor. What else causes LOTS of oil in the water and maybe 1 pint of oil in one cylinder?
Dean
mail4dean@aol.com
http://answers.edmunds.com
MODERATOR /ADMINISTRATOR
Review your vehicle
Water pump started puking water everywhere, so figured while we were replacing that might as well change the timing belt, etc. Got everything off ok, with a little elbow grease. Have new belt on, but can't get marks to line up. Got advice from a Master Mechanic to put belt on right side while tick marks are lined up, then clamp belt to upper gears so they won't slip while putting other things in line and taking slack out of belt.
Problem is, we have another 'somewhat back-yard' mechanic telling us our cams are out of synch with the crank. Zero clearance motor, so no room for error.....
Any thoughts or tips on getting this right?
About two weeks later, I noticed the heat stopped working again. I added more coolant to the system, and it began working again. Now I seem to be stuck in this pattern. Heat not working/add coolant/heat working again.
There are no noticeable leaks ANYWHERE, and I have replaced the radiator cap as well. No boiling sounds or other problems whatsoever.
Anybody have any idea what's going on? My mechanic suggests a pressure test. But I just don't know.
Thanks in advance.
