Chevy Express Transmission
I have a 1999 chevy express 1500 conversion van. When the engine and transmission are hot due to long idles and hot outside temps the transmission shifts hard and jerking when in drive. If I shut off the engine and wait for 5 minutes and restart the problem goes away.
On a side note, I do not belive in oils at all, but I only use amsoil in transmissions I like, and the operating temp of amsoil is much broader and higher then the cheaper dextron 3 fluids available.
Most good scan tools, "scanners" can plug into your aldl connector under the dash and read the actual trans temp (in some pcm's) and see line pressures in the trans. A good trans shop should be able to do it.
If the engine is also running hot, that is causing the trans to heat up. The trans is cooled by engine coolant in a seperate cooler in the radiator. If your engine is running hot, look at the pump, the thermostate (low temp thermostats are available), and the fan, radiator blockage.
Does anyone make a pan that is deeper but only in the front half?
