Kia Sorento Timing Belts
I have a 2005 Kia Sorento. It's my understanding that timing belt must be changed around the 60,000 mile mark and I'm getting close. The price of the actual belt is under $100 but was quoted $900 to replace it. What gives? Do they have to pull the entire motor to replace on of these things? Does this cost sound correct to anyone??? I can almost replace an entire motor for that amount. If anyone can shed some light on this, I would be grateful! Thank You!
I'm in the same boat but haven't asked about the cost yet. I've always done most of my own maintenance and can't understand a timing belt on a V6 engine. Usually, timing belts only exist on smaller 4 cylinder engines while V6's and V8's had timing chains. Maybe I'm just showing my age. It will be interesting to see what this brings.
and yes it is a major motor take apart to get to the drive belt internal to the engine.....KIA scheduled maintenance is often and $$ IMO....differential fluid changes every 25k, oil changes every 3K......and many stories on the board if you cant fully document all your scheduled maintenance, warranty repairs have been denied......
wait till you change the spark plugs!!
I have 106K on 05 Kia. I have not had timing belt changed yet. I too have gotten prices of up to 900 bucks to have it changed. If you have not had your recall done on ICV then perfect timing. Get both fixed at same time. They will have motor out already therefore charging me about 450 bucks for timing belt since warranty work (ICV) will cover labor for taking motor out. However still going to complain since belt only cost 100 bucks. still way too expensive. BUT YES BEST THING TO DO IS TAKE LOSS NOW. looking around lately and only getting 3-5 K for trade in values for my piece of sh..!!
if they replace the engine under warranty, I wouldnt argue over the serp belts...they are about $100 for the three of them.....
The lowermost one is the crankshaft pulley, which has a bolt recall (03 sorento). If this bolt breaks, KIA will also give you a new engine because it is easier than to fix it. At least that is what the rep told me. I think they charge 5 hrs of labor at 100. each + parts.
While my sorento was in the shop I had them replace the timing chain at around 60,000 and now it appears that the crankshaft pully bolt was torqued inproperly and it snapped off yesterday while I was driving and I almost crashed. How on earth can people doing shotty repairs sleep at night.
I called national Kia and tried to get satisfaction through them, but I was told that after 60,000 miles they no longer have road side assistance. It appears even when they do a repair improperly and send out dangerous vechicles that applies. The first representative I spoke with told me to drive the sorento in--even after I told her that the crank shaft bolt snaped. I told her it wasn't driveable. She told me that basically it was my problem. So I got the manager's boss who told me that they would cover the towing cost if it was found out by them that it was caused by an error in the previous repair. So I guess I have a lemmon that is falling apart at 64,000 miles. This is incredibly disheartening. :lemon:
Now I have to get a tow truck to take the sorento to a different kia dealer repair shop that is in the bronx. I feel very powerless in dealing with this supposed great warranty.
See TSB No. KT2009081001 issued 8/09 that they have on the proper installation of the crankshaft pully bolt.
To learn more about recalls, TSB, etc. go to http://www.kiatechinfo.com and sign up.
I'm beyond disgusted with calling kia and trying to get satisfaction after having their representative Yonkers Kia dealer repair lying and saying that the transmission repair was done properly and then having to call Kia national to complain to try to get the problem resolved. :sick:
Now it is the shop again because the harmonick ? balancer went so this is going to cost around 300.00 to fix
anyone else had the same problem
please advise
BTW..130k on your sorie with those repairs isnt unusual...timing belts in the 03s are changed every 60K under the published scheduled maintenance....replacing the H20 pump was a good move as it saved extra labor....pricing seems about average....but slightly on the higher end
2 days ago I was driving to work, the car was a bit noisy and heaving and then the steering jammed. I immediately pulled over and stopped the car, switched everything off and re-started, when I put the air conditioning on the car was worse, since I was about 200mtrs from my office parking blg, I managed to get there, park the car and called the dealer. I explained the story and he told me to drive it to them but keep the a/c off. I declined to even think about driving a car in such a condition and called my insurance to sent a tow truck. They did and off it went to the dealer. To cut a long story short, it has been with them for 2 days and apparently has a catalogue of problems which will cost a fortune to repair. Snapped engine bolt, bent crankshaft, damaged bearings and pulley, hardened timing belt. My car which is in pristine condition and only done 49,000kms suddenly falls to bits? how can that be? I am convinced that faulty parts are to blame and after reading your forum am now positive and worse than that, KIA are well aware of this! Thank GOD it happened in a quiet area near work and not on a major highway with the kids in the car. I have not given the go-ahead for repairs as quite frankly I believe KIA should be held accountable and fully intend to put in a complaint. Can anyone advise of the most direct and effective link to top KIA officials, I live in the Middle East and the local dealer is insisting that since the warranty has expired that I should bear the costs. As far as I am aware the timing belts should be changed at 40,000kms and they did not do so.
