JGC electric fan vibration?
If the electric fan is vibrating can it be fixed easily? what can I do to fix the problem. It just started today the steering wheel vibrates and the fan shroud and radiator vibrate when the fan is on. Any one had this problem?
with key off take flash light and look the fan over sounds as if you lost a fan blade
replace compleat fan assmbly i got mine from jeep for 140.00 compleat and was not to hard to replace bearing went out of mine
