2006 Subaru Outback CV Boot Dilemma!
Hey all, I own a 2006 Subaru Outback with 60,986 miles about 250 miles ago my pass CV boot ruptured spilling it's guts all over my engine. This isn't so bad, fluke right? Wrong, my car is back in the shop right now getting the drivers side front CV Boot replaced because it ruptured 250 miles later. This is unacceptable to me. I own a 1995 saab with almost 200,000 miles on it and I've never replaced a CV boot.
Is anyone else having this problem? How much should it cost to have this replaced at a dealer. I ended up paying $200 for the last one and they just replaced the boot. Is this high?
I've contacted Subaru about this and I am yet to hear back. I'll keep you informed.
I replaced both axles on my '96 outback due to boot failure (nearest the wheel) at around 130,000 miles and 8 years of age. Lifespan of those boots is highly dependent upon the conditions to which they are exposed (I live in Fairbanks, Alaska, so the winters are hard on them), but I would think your Saab has experienced the same conditions as the Subaru, so that can likely be ruled out.
At any rate, I would say they failed prematurely barring any damage from an external source.
It is in Maine now but it is yet to endure a winter.
Cheers
Conor
Never replace just the boot because once the boot is torn dirt has entered and contaminated the cv joint.
-mike
The Mazda dealer was always overpriced so to be honest I'm glad we ditched that car.
I don't think $200 is that bad, I'd have been thrilled to pay 1/3rd of what my wife paid for her Mazda.
To make matters worse, the grease spilled on to the oxygen sensor and blew that part out as well. Add another $220 just for the *part*! Ouch. :sick:
-mike
They said they had to take it off to rebuild it.
Later Pat told me there are kits where you can do the fix without removing the axle. It was the wife's car and I usually work mostly on my cars.
-mike
This was the front axle on the 626, which is FWD and had that V6 crammed in transversely, with the tranny under it. A crowded mess, basically.
Cheers All, thanks for the advice.
-mike
Motorsports and Modifications Host
Getting the transmission apart from the block may require an air chisel to split it apart. Also try some good penetrating oil.
-mike
Subaru Guru and Track Instructor
Here's how I did it with mine, twice:
First, place a floor jack under the transmission pan, and lift the jack, with a 2x4 (or other large-surface-area block of wood) between the pan and the jack to avoid damaging the pan, just to the point where it connects with and applies slight pressure on the transmission. Then, remove the support the connects the top of the transmission housing to the firewall of the car. It should be very obvious, located directly on the top of the transmission and exactly centered on the firewall. You need only remove one end, firewall or transmission, not both. Once disconnected, swing it out of the way. Now, your transmission has some wiggle room.
With your engine attached to a puller, lift it a little. Now, lift the jack a little until pressure is applied to the transmission again. Rinse and repeat. Okay, forget rinsing, but you get the picture. Once you get the angle just right, you should be able to separate the engine with some forceful wiggling. There are two short (3/8" or so?) studs on the transmission that align it with the engine, so once you separate it that far, they should pop apart rather suddenly. Then, you simply slip the engine out of the bay.
Oh, now that I look, you did remove the flexplate screws, right? If not, you will find the removal to be... challenging. I assume you did, but if not, there is a covered access port in the back, top, left side of the block. Pull off the rubber cover, turn the engine using a 22mm socket on the crankshaft bolt until the first bolt appears in the access, then remove. Repeat for all five (or were there only four?).
Apologies....
A rock tore a boot on our Mazda 626. Not much you can do but change it. The grease shorted out the 02 sensor so it cost a bunch to fix. :sick:
