2001 Isuzu Trooper cuts out and dies while driving diagnostics not helpful.
2001 Isuzu Trooper Limited cuts out and all gauge lights come on as it starts to die. If we keep giving it gas it will keep running sometimes. When it dies completely while driving we can restart in Neutral. We had Firestone do a diagnostic on it, they had it on the rack for 1 ½ days and said they checked everything and could not find the problem so it must be the Computer and that we should take it to an Isuzu dealer to heck and fix the Computer problem. The Isuzu dealer in St. Peters, MO. Said that they tested the Computer and found no problems. They said that the problem was carbon build up and that we needed a carbon clean out. After having the carbon clean out the problem remains. The problem started out once a week 3 weeks ago and progresses to 4 or 5 times daily a week later that’s when we took it to Firestone. Ten (10) days ago Isuzu did the carbon clean out and now the problem has continued to get worse, it happens every 6 to 15 minutes. We moved from St. Peters, MO, to Ames, Iowa a week ago after getting the car back from Isuzu. This was a very stressful move because of this problem. I have some automotive knowledge and amy not afraid to get my hands dirty. This is getting expensive. Please help us if you can. Thanks and have a great day.
My daughter's 2001 Isuzu Trooper with 89K miles is using oil real bad. I had the oil changed and about 1000 miles later I noticed that there was no oil on the dip stick. There are no visible signs of an oil leak. Does anyone have any suggestions other than checking the oil weekly or bi-weekly and toping it off ? I would appreciate your help !
gasket? who told you
to do this?also do you recall what this might cost . because i would like to
give it a try. anyone else tried this solution yet?
After reading these posts I am wondering if the problem is the intake manifold gasket? Any suggestions? Should I ask them about the intake manifold gasket, take it somewhere else, etc. I hate to immediately be so suspicious but there were never any signs of a problem of this proportion and the repair shop is quite aware of my ignorance reagrding cars. Is it possible the engine or motor may need to be completely replaced? Any ideas, help or suggestions would be greatly appreciated!
Hunter
My quotes thus far range from 3700 to 3900 to 4260 used and 6000 to 6610 new. It's makes me 'sick' just thinking about it. I love my Trooper!!! If I had gotten any indication that it needed oil at that point (oil light NEVER came on) or that it was even hot, I would've stopped at the next exit and handled it. Now, I'm faced with the dilemma of fixing it or buying another car. At least I'll know to keep the engine thoroughly juiced if I do buy the engine.
P.S. Oh, I'm also told that they have to pull the front end off to remove the engine, which makes it an even more laborious task.
Gryph
(Disgusted!)
