Mitsubishi Lancer Starting/Stalling Problems
 packheat
                    Member Posts: 5
packheat
                    Member Posts: 5
                    I purchased a 2009 Lancer ES three months ago and have been experiencing starter problems. It'll happen once every 9 or 10 starts (so at least once a week). I'll turn the key and no start. Then I'll wait a few seconds and try again and it will start. Has anyone else experienced this issue with either a 2008 or 2009 model? I'm going to let my dealer know when I go for my oil change in a few weeks but would like to get some feedback.
Even if a 1/2 inch difference will not start the car.
I drive a manual so I always step the clutch all the way to the floor.
I have 37,700 miles on my 2008 Lancer.
Service light should reset after 6000 miles or else it will keep on beeping
And clutches break because of being "ridden" is one reason. What I mean by that is pushing in on your clutch(while not even realizing you're doing it) while driving along. It will smash and scrape various clutch parts together with friction and they'll eventually break.
The '03 Hyundai Tiburon seems to be notorious for this problem. Only Hyundai isn't stepping up and fixing the problem for people. You're almost better off these days to buy an automatic, they seem to hold up better.
Honda's are good for tranny's and clutches, I hear, though.
I think you're right about buying an automatic though. These days, not much NEW technology is being put into improving the manual transmissions. They're almost devolving and are only $1000 dollars cheaper than the automatics.
