Pontiac Grand Am Engine Trouble
i have the 2.3 Quad 4 SOHC and its a 92 grand am SE i decreased my engine about 2 months ago and it just started to seem like its losing power and misfiring so i changed the plugs and boots still didn't work so i changed my coil packs and housing and it ran real great for a week and then when i was driving to work it just seemed to be lacking power again and at the light it just died when i stopped and i started it again it ran for a sec and i hit the throttle and it died and started again and it barely made it off the highway and now it takes a good 5 sec for it to start up and is still seems like its misfiring but the plugs look normal and im wondering if it might be my fuel pump, filter , injectors or a short from when i decreased it any suggestions would help thanks
No warning until one day on start up - excessive rev then it will settle down until shift into gear then excessive rev and instant load until it stalls under brake/load. Car will drive but stays in gear even under braking/stopping.
Does anyone have any ideas where to start looking.
I changed the Trans filter/oil because I knew that had not been done. No luck
Acts like the Tourque Converter is stuck. Is that possible?
Help please my daughter needs her car so she will leave mine alone
More info is needed such as does it crank? Does it smell? What does it sound like when cranking? ( metal in metal or rattle)
It may not be any problem for a long time, but it's an indication that the engine is worn, and at 183K miles I'm not surprised.
If you rev it in neutral then let off on it quick, do you get the noise when the engine is warmed up? You may have to punch it kind of hard, like to 3500+ rpms.
I has this occur on my MGB also, and found that one of the rod bearing shells was broken in half and worn bad.
I have an 03 GA 3.4l V6 - new plugs & wires, coil packs, new fuel pump, swapped MAF sensor & fuel pressure regulator (no change) car runs rough acts like too much fuel, cat turning red, putt putt sound...SES light on and was coding P0300 random multiple misfires. Not losing oil, not losing coolant, no overheating. It is going to the mechanic's but it would be nice to have more of an idea of what it could be!
CrimsonGlory
