Acura 2008 TL Type S
Hi I just purchased a 2008 TL Type S a few weeks ago and I love it so far. I just have a few quick questions.
1. Back in the day, I always used to have my first oil change at 1000 miles (due to break in period). My question is do you think I need to do this with this car? Or is that overkill since the technology has changed over the years?
2. Somewhere between 75-80mph there is a slight vibration in the steering wheel. Should I get a high speed balance done or is there a TSB for this that Im not aware of?
That's all I have right now. Thanks in advance for any/all replies.
Do you think it could be anything serious? I can try to bring it in sooner but I'm just really busy right now. But if I have to make the time for it I will.
best rule of thumb when i have balanced tires is to rule out balancing issues
1. break the front tires down for the rims. let the air out, break the seals and rebalance the tires completely as if u were putting on new tires. Sometimes the tires seal wrong. I have had this with many aftermarket rims and tires. After re-doing them ,they were fine...Try this 1st, if its not that, then you have another issue above.
however your car is new so the dealer should take care of it.. make a stink. get it fixed.
Any ideas? I just fear it will continue to get noisier and sound like an old clunker.
I recently purchased a 2008 Acura TL Type S. My first new car in 18 years. Prior to that I drove a 1990 Toyota Tercel that I never bothered washing or cleaning.
Consequently, I have some silly questions about cleaning the interior of my TL.
1) What should I use to clean the seats? Some kind of leather cleaner? The seats are leather, correct?
2) What should I use to clean and care for the dashboard? Is the dahboard vinyl or does it have a leather covering?
I have no experience with anything other than vinyl (seats, dash, etc.).
Thanks for any suggestions and help!
Does anyone have a similar problem, and if so, how have you cured it?
As fo rthe seats I use LeatherCPR, totally awesome. No film or residue, cleaner and condition in one and leaves leather feeling soft and supple.
I kept reading about road noise here, but mine seems to be different.
Dual Trace
However something really bad showed up when they washed the car. Water leaks badly (pours) around the ceiling lamps. They also said the windshield is not the original Acura one and thought maybe it was not properly sealed, etc. They advised me to take the car back to the non Acura dealer I bought it from and if they can't fix it, then they should contact Acura dealer and they will fix it and charge the other dealer.
All the controls underneath (navigation, heating, stereo, etc.) and the transmission stick were soaked.
Took the car to the first dealer and asked money back. They said the only option is to trade it for another Acura. I left the car there because they need to fix this anyway and told them I will weigh my options until the leak is fixed. What's your experience about returning a used car within a week of purchase date?
Its called torque steer- that's what you get when the car is driven by the front wheels plus all that power.
Does anyone know a good place where I can get my Audio system repaired, I have something stuck in the cd changer and the CD/DVD audio will not play or change discs. I live in Dallas, TX. Any help will be greatly appreciated.
Thanks in advance.
