Chevy Colorado and GMC Canyon Climate Control
I have something caught inside the heater fan, I think a may be a leaf. I had the same problem before when the truck was under warranty so the dealer removed it. Now I would like to get some info on how to remove the fan and get the object out.
Thx,
-Brian
Thx,
-Brian
Low side pressure reads25-30 PSI ,High side reads 350 PSI but spikes higher when low side drops.
On my cadillac the compressor was internally self destructing & filling the system with tiny flakes of Chrome & other metallic particles which blocked the expansion valve.
as for the Colorado , since it is still under waranty I will see what the dealer I bought it from can do about it.
( I've been a mechanic 25 years so it should be fun to see what answers they offer )
AC Blower was intermittent on several speeds but High always worked. Local dealer owed me a favor for a service issue on wife's G6. I believe they pulled th dash to fix it and did me no favors in doing so. Motor worked properly for a while aftrwards, but ac began freezing up despite proper freon levels, suspect an airflow problem. Found the existance of an "GM Engineering bulletin" on the blower but never found the details. Now, have experienced similar intermittent electrical within the truck to include: Cruise Control, Stereo, Wipers...suspect a larger ground or harness issue. Very disappointed with the engineers at GM, quality and dependability in electronics should be far greater then this. Despite loving this truck, I am nearing the decision to let Car Max send it to la-la land. If anyone else has been through this and has a solution, please advise.
All of these things can be assessed without taking the dashboard apart.
Find the blower motor resistor and remove it to make sure that the resistor is not fried, if it is you can get one a NAPA for $20. If it isn't then just look at the female and male ends of the connection and check to see if it has been burned up. If so replace harness, if not all you have to do to get the intermediate fan positions to work is to take a small screwdriver and slightly bend the "male" connectors so that they better contact inside of the female end of this connection. Very easy and cheap
if you need more info let me know
kman
look for the blower motor and it is part of that assembly area
there are two bolts holding the resister block into the assembly
look for the connector ( white in color )
good luck --- i hope this helps
I'm having a problem similar to capfsu had. Had the clicking noise, but kept trying the knob. I guess I twisted it a bit too much and a piece of plastic on the back snapped. I had to replace the whole system, but now, after I hooked up the heating control cable, the knob on the new one will only turn so much. I get resistance at a certain point when going towards a warmer temperature and if I keep pushing, the retaining clip will pop out, meaning I have to pull the whole panel off again and reattach the clip. So now the wire will only go in so far and the temperature will only get so warm (not warm enough sometimes!).
Is there anything I can do to this wire to get it to push further in, like it should? I'm pretty sick of all these Colorado problems. Have this issue, the blower issue, and now the valves on the head are going bad and I'm past warranty...
Thanks for the help on the wire.
