Can I sell my 4Runner for parts?
                    I'm not a car gal, so please forgive any hokeyness with my jargon.
'96 4Runner with about 175K on it. It's at the dealership right now, dismantled, with a leaky head gasket and two cracked cylinder heads. (Tech says there was a coolant leak. I'm :mad: the dealership didn't catch it at the last service.)
Fixing it is not an option (the dealership shop wants $5K for a used motor, or $6,500 to put in new heads & gasket). AutoTrader says it's worth about $6,200 with its clean history, if it were running. I'm not in a position to sink that much $$$ into it. We're up to $700 in tear-down right now.
I don't need a replacement (have another car).
Not going to take out a loan.
I've got to cut my losses, or find a cheaper way to fix it. (Like in the neighborhood of $2k or less, on top of the $700 I've already got into it.)
I'm not sure how long I can let it sit at the dealership without annoying them--I've known about this for less than 24 hours, so I think I've got a day or so. I'm doing all I can from here, and I've got my Dad calling car guys he knows, but it would be good to have some additional expertise weigh in.
Thanks so much!
Thanks so much!
Is there a way to use the VIN to find out?
Off to find out how much it'll cost to tow it home . . .
Are you fixing it at home? If not, you will pay to have it towed again to another location.
I brought my 4Runner to the dealership, and they replaced the head gaskets and associated parts for FREE. They still tallied up the cost, and it was way over $2,000.00 for these repairs. I am surprised they are charging you for something that they sent out a Recall on. :confuse:
Only thing I can think of, is maybe the year of your 4Runner wasn't included. If I can dig up the paperwork on this (which I do have), I can send you more information. I would definitely ask about this. Good Luck and I hope all works out well for you
--Patricia
Here is a link in regard to the Toyota Head Gasket issue:
http://www.brian894x4.com/V6headgasketrecall.html
Not sure if there is anything you can do about it at this point, but it wouldn't hurt to investigate. As I said prior - - Toyota completely fixed my head gasket problem on my 92 4Runner for FREE. Hope this may help you.
--Pat
