Honda Civic Noisy Interior
I'm so disappointed with one aspect of most Honda autos. How much road noise is introduced into the cabin. I just traded-in a 2008 VW GTI for a 2008 Honda Civic EX. Unfortunately VW has questionable reliability but that's a different discussion. One highly noticeable difference between my 2008 EX Civic and my old 2008 GTI is how quiet and solid the GTI felt. I also test drove a 2008 TSX, Accord and they were also noisy. Honda why can't you add 10-15 pounds of additional sound dampening to make the car quieter? Being connected to the road means steering wheel fell, handling and not road noise!
1) Make sure your tires aren't overinflated, as this will transmit more road noise.
2) Buy quieter tires. The stock tires are quite noisy on rough surfaces. Both the Goodyear Assurance Tripletred and the Goodyear Assurance Comfortred are known to be much quieter tires, and I plan to try them on my 2008 Civic when I finally wear down the stock tires.
3) Install aftermarket sound-deadening materials. It's a tedious job, but from what I've heard it really works. I may try this myself some day.
4) Earplugs! Not kidding.
5) Buy an Accord next time. Still not kidding.
Since I plan on keeping the Civic for the extreme long run I will be doing the after market sound dampening project. BTW, I highly recommend searching on the net for the best do-it-yourself suggests for quieting the Civic. I already did the rear trunk but I failed in some of the recommended methods. My lesson learned is sound dampening needs two materials. You should plan on using a Dynamat like product for the areas with thin/tight installation space. Use a good quality carpet padding material in say the trunk/flooring. I imagine the best solution would be to use the Dynamat all around however its expensive and heavy. Cover everything that is recommended or you might find your hard work was a waste. Oh and it will be tedious.
Please let us know how your sound dampening project turns out!
David
I will also be buying some better tires when these are shot.
http://www.8thcivic.com/forums/i-c-e-electrical-security-navigation/93636-sound-- deadened-civic-weekend.html
Like I said I took a minimum approach. I tapped on metal and if it had a dingy sound I applied B-Quiet Ultimate. I did my trunk and inside floor area with the B-Quiet VComp and Second Skin product. I did my doors with the Ultimate product only and followed the process as seen on the link. The hole thing took 5 days. However I did it over a period of one months time. So was it a success?
Yes and no. The car is definitely different and improved. I just didn't match the GTI. I now know that my goal was to high. Also my minimalist approach was wrong. I spent approximately $450.00 plus my time. The added weight is approximately 80 lbs. I believe the Second Skin product is better. If I were to do this again on a similar Civic I'd probably use another 25 pounds of material and cover as much as possible with a product like B-Quiet Ultimate. Then follow it with the VComp like product which is heavy. I don't know if placing it on vertical surfaces is a good idea unless you know how to glue heavy material on vertical metallic surfaces. On horizontal surfaces its the material that blocks out the sound coming from the road.
Unless a car is completely gutted and a full makeover is done it will only turn out as a partial solution. The best thing is to buy a auto with sound dampening as part of the design.
I took the car back to the dealer and they said nothing is wrong, however, I hear it all the time and so does anyone sitting in my passenger seat.
My rear view mirror shakes (quietly) even if I am on smooth pavement or road. The dealer said they would replace it. But they claim there is nothing wrong with the car.
I really want to get rid of the car. I don't feel like this is acceptable. It has 250 miles on it and it has made this noise since the 2nd day.
Honda should stop using firestone tires.
I bought a little more material than was needed mostly due to minimum buy vs price. You can probably save $50.00 dollars by buying smaller quantities but then you're left with using the product sparingly.
So again Honda makes reliable, fuel efficient, inexpensive cars that aren't luxury feeling like the German brands. Oh Acura is not a quiet car either so paying more doesn't equal quiet, at least not for Honda.
any thing upgrading from a 16" steel rim to a 17" alloy would make a difference in the cabin noise?
btw: I heard Honda's answer to quieting down the Accord was to use noise canceling speakers in the cabin. I wonder what that might cost to install in a civic??
I have a 2012 Civic EX 4-door, which I'm sure some of you know has taken a lot of flack given its lackluster interior ushered in with the 9th gen. redesign. I agree to some extent that it looks cheap, but part of me appreciates the hard plastics and such as I feel it'll prove more durable given the life expectancy these cars tend to achieve.
I bought it new and it now has 15k miles on it after two years of ownership. Of course, when I first bought it the road noise was not an issue, but as the miles have passed, noise has become an all too familiar and tiresome companion. Where I live, we have particularly poor roads, and i swear my Civic sounds like it's falling apart. I agree with many of you that Honda needs to add more materials to isolate the cabin and suspension components (I haven't driven the 2013 model, which Honda claims has more sound isolation). What really disappoints me is that, at 10k, like many of you, rattles have started to crop up. At the moment it's the glove compartment and BOTH rear door panels. Just last week, my drivers door has started to rattle to any sort of bass coming from the speaker mounted in the door. I don't really mind as I'm grateful for having a car in the first place, but Honda products are not what they used to be.
I have to weigh in and also agree that my 2012 Civic Coupe is the nosiest car I have ever owned. My last Civic Coupe (a 2004) was a quiet and solid car. I've owned 3 Civics, but I'm afraid that my current Civic will be my last. Honda has compromised everything important to squeeze out a meager increase in gas mileage and make their profit. Sadly, this will be their downfall...
