Pontiac Solstice Tires and Wheels
                    does it concern anyone that the solstice doesn't have a spare tire?
Imagine your wife (or you) in the dark,in the rain, on a deserted road or busy interstate performing the tasks required. You can always purchase "run flat" tires @$400.00 each with 30,000 tread life or "puncture proof tires".
as for the spare tire.....the cadillac CTS as an option.....but otherwise you have the same kit as the solstice in a $45k auto......I opted for the spare tire in my 09 CTS...but am ok with the inflator kit in the solstice......
this is a growing trend to cut costs and weight....no steel rim, tire, jack or wrench...
I took it to a repair shop(not just for tires, general mechanical shop)and the owner said that his repair would not be warranteed, because it was to repair damage to the sidewall of what was now my left front-located tire(after rotating the tires). But it was that same tire repaired months earlier at the Standard Chevron. They fixed it with the plug method all over again, it was slowly leaking from the earlier repair. It has now held up for what must be 8 or 9 months now. No Tire Pressure Monitoring System warning lights(my Lancer GTS has this...that's what initially tipped me off that I had a problem needing attention) and no slow leaks or tire failures of any kind. I didn't know if I would like this TPMS deal but it works nicely...flashes a warning that a tire is low on air. It has worked properly every time it's sounded a problem, so no complaints from me on that system new to me on this car.
Long story short, yep, you're right, your tire repair kit would work fine for most tire failures. Ya learn something pretty much every day on Edmunds...if you really want to!
Hopefully your wife is smart enough to press the blue OnStar button and have Pontiac Roadside do it for her for free.
