All I have ever gotten out of those explanations is that it has something to do with the mechanics of the center diff'l vs the front diff'l vs the rear diff'l configuration. Number of side, spider, gears in each..?
The same thing would occur with a R/awd system too because if the wheel spin occurs a the front, power will be routed to the slipping wheel unless you have an active (i.e. Torsen or equivalent) center diff because power will ALWAYS go to the wheel of least resistance (i.e. slipping wheel). If the F/awd system has an active center diff, it will send the power to rear wheel this situation just like the R/awd. Even your explanation for the different awd system concede this. So I don't know how you can conclude that a R/awd system is better.
Hence, it doesn't matter whether you have a F/awd or R/awd system, it all depends on the type of front, center, and rear differentials. If they are all open, then you have a essentially one-wheel drive vehicle. Very few car-based vehicles come with Torsen center diff or locking/limited slip front and rear diffs anymore. Most use TC ABS to simulate resistance/friction.
Here's an interesting article on why FWD and AWD system based on FWD are better than RWD and AWD system based on RWD in low speed low traction situation.
http://www.thetruthaboutcars.com/2012/02/avoidable-contact-color-my-world-the-ca- se-for-front-wheel-drive/
