Chevy Tracker Lights and Headlights
1998 Chevy Tracker 4WD 2 Door Soft top
I was driving down the freeway and a car just in front of me had a tire blow. It pulled over to side and I kept going. Later I saw a wheel weight sticking out of what was left of the glass in my passenger side headlight.
I found a headlight assembly and bought it but need to get info on what I need to do to change the whole assembly.
Do I take the whole front grill off? and what else do I need to change and then I presume I need to have the headlight aimed... This seems to be a major production LOL...
I looked in a cheap "how to" manual but it doesn't have much on body work...
Any online suggestions or how to suggestions.
And I love my Tracker...wish they still made them...
Any Ideas?
The check engine light is also on. Having had the code checked at my local shop, they said it was the front O2 sensor, but they have no idea how that could cause any blinking...
I removed the ground wire up against the chassis and brushed it well, tested the battery to no avail.
Any help would be greatly appreciated.
It sounds to me like the voltage regulator in your alternator is spikeing. A normal alternator test may not show this. The easiest way to find out is to connect a cheap "analog" voltage
gauge to the output terminal of the alternator and extend it into the vehicle so you can watch it while driving. The wire from the alternator to the plus side of gauge. The negative side to ground. You can't use a digital gauge or meter because they won't show a "pulse" Where an analog gauge with the needle will. If the lights spike with the gauge needle, it's the regulator for your alternator.
This problem is a tough one to resolve. Initially the alternator tested fine (as others had reported in this forum and other Tracker forums). The bad alternator/regulator caused other problems to materialized that the auto's computer was trying to compensate for. Once the new alternator/regulator was installed the blinking/flicker lights stopped and other problems disappeared. My other recommendation is to buy a new alternator rather than a rebuilt. The cost for the part was only $30 more than the rebuilt and I believe will make a difference in the long run.
Good to hear that it was the alternator/regulator combo that was causing the problem.
My decision to go with a new alternator verses a rebuilt was that in another posting in this forum on the same problem had issues with rebuilt alternators going bad in short notice (I hope you have better luck with your rebuilt alternator).
changing the low beam headlight, i started this job thinking what a nothing chore,
wrong i had to remove several components from the engine compartment, i had to wedge a block of wood between the washer fluid tank to allow access to the light bulb.
this may work for others, grab the light bulb insert with a pair of pliers and twist counter clockwise. it needs about 1/4 turn. the wiring harness may have to be stretched.
good luck. changing a sealed beam use to be a nothing job. listen up automakers
They take halogen bulbs and I am considering replacing them with old style glass sealed beams. Anyone have this problem or find a fix?
Papa George
So I told them to replace the alternator/regulator (original, I have to add) anyway and in a Midwest metro area of 1.2M people, there isn't a new one or rebuilt one to be found! Not even looking under Vitara, and not at Chevy or Suzuki dealers. (I checked and found the same, although I could order rebuilt ones from a couple of chain parts stores with 2-3 day delivery IF this snowstorm hadn't crippled the East!) Since this shop rebuilds "in house" as a specialty, I let them do that. Took two more days to get the stator and regulator they needed! Okay - three full days out! (I will say they are nice folks and this job cost me less than the price of a chain-supplied rebuilt alternator! All their work is warranted two years.)
Got it back yesterday and haven't had a chance to get out on the highway the required 10 minutes to get it to act up. Today, maybe, once the roads are cleared of ice.
I DID find out the DRLs can be disabled by removing the DRL Relay and bending over one tab then putting the relay back in. I will not discuss which tab. I think you'd better know what you're doing and better have a spare relay on hand in case you make a wrong move and also break that tab. (I have a spare and intend to try it today.) There is information elsewhere on the Net. Maybe one reliable post.
The auto-on lights "can" be disabled at the photo-sensor on the dash, but this requires some knowledge and some electrical skill, so I won't go very far into that either other than to explain you have to remove a couple of wires at the cell and insert a rather large in-line resistor of a certain size, between the two wires, and put the whole mess back inside the dash. I imagine it would pay well to test it first. Then you should secure those wires somehow up where you can get to them later. Again, a lot of searching on the Net will get you two mentions, one of which is not correct. Resistor comes from Radio Shack and you'll want a couple of cheap connectors so the change isn't permanent.
I'll report back later.
At 133K miles, this being one of the very best vehicles I've ever owned, and easily my favorite out of dozens, it's plenty worth a few repairs, to me. (We have a 2007 Kia Rondo right now that is quickly edging the Tracker as the best and my favorite!)
This is caused by an EGR Valve vacuum leak. I think it cost me about $300-$500 to fix.
I had the problem with my lights blinking. I think I finally found out the tension idler was not holding the belt tension tight, and it lets the belt slip.
When the alternator is pulling hard, the belt slips and re-catches. I have changed my tensioner and it seems to have cured the problem
Hope this works for you
Jesse
I returned for the Tracker and he said the AC looks fine, I replaced the serp belt, sparkplugs, and smog. Everything is good. Okay.
I received no satisfaction regarding the AC issue with him either, so I took it back to the original AC place. He did some more checking and found that the previous owner had installed an alarm system (which was removed when I purchased it) and said that there was a bare wire, so he capped/taped it. He says strangly the AC compressor was surging 20 seconds on then 20 off, and so on as it cycled. He told me not to run the AC as it was damaging the new serp belt, and not to run defrost as it cycles through the AC compressor. Now, driving the 75 miles home, the 4 wheel driver dash light flickered off and on when I turned on the fan---whether using the defrost or AC. It flickers. Turn off the fan...no flicker. Now What?
I take it back to the AC fellow and have the compressor replaced. I could survive the 110 degree heat in his town, but not being able to use the defrost come this winter would we disaster. I live in the mountains/snow. So, I was happy! But, the light still flickered! And the AC still surged! I took it back and he said he couldn't figure out why the flickering, but removed all the wiring harness from the previous alarm install. Still a flicker, still a surge. Some days no surge...some a lot. You can hear it click on and off, especially if standing outside of the Tracker.
AC fellow researched on line to no real help. Said possibly the $500 AC 'board' 'brain' may need replacing, but wasn't sure. So maybe?
Anyone with any idea? Anyone with a wiring scmatic to the 4wd light and fan switch? Or where to find it?
There you have it. I love this little ride, but ready to rid myself of it. 2 transmissions in last 4 years, acuator pump, rear seal, this ac.... nickel and dimes keep falling. Almost out.
would anyone know if the alternator was good but the regulator was bad if it would hurt the tracker if I did not replace it? The lights are pulsating and owners of trackers on this forum say it's a bad regulator. I just don't have the cash right now.
