Acura MDX Bluetooth problem
I have a 2007 MDX ...I have used the bluetooth often with no troubles, but lately when I dial up using voice activation everything works but you do not hear the ringing or when the person picks up. I do hear it faintly on my cell phone that I keep in the cosole or my purse. So everything is working but it is as if it is on mute. Same with incoming calls it rings in the car but when I pick up it does not come over the speakers. I have read the owners manual and have made sure the phone is in sync...
Help please!
Help please!
We're all spoiled brats. Good luck.
Any input would be greatly appreciated. Since bluetooth is such a huge feature to someone who needs to use the phone a lot while driving, this could affect if we buy an MDX vs. something else.
I have a Touring MDX 2005. The hands free button seems non responsive. Everyone once in a while, it will be available, but won’t stay paired. My next step is to see what wiring I can check, as well as fuses, but I don’t see anything in the manual for Hands free fuses. Thanks,
On the 2007, pulling the battery out of the phone seems to do the trick more often than not. ONCE I did have Acura do a full RESET to factory default on the bluetooth mechanism in the car before things came back to life.
To this day i am still disappointed in the sound quality of the 2007, 08, 09 bluetooth as it is ported through the AM radio channel which is blurry / dull sounding and hard to hear most of the time.
My 2 cents....
I have an A2DP compatible phone.
Am I able to stream bluetooth audio to the car?
I had the dealership change the bluetooth system but the problem continues.
Also, the bluetooth doesnt automatically recognize my phone -- I have to turn the ignition off and on again for it to recoznize the phone
Much appreciate your help.
I had the same issue with my 2006 MDX. The bluetooth died a week ago and I am lucky to fix it myself. Thanks to somebody who posted online with his experiment. I even also called Acura dealership but their price is too much. Just the bluetooth module itself cost $360.00 plus tax plus if you let them install for you which is very easy to do will cost more than $600.00. This is a rob. I read a post from someone in another site and awesome it works. Just follow the instruction and you will find out.
Here is the site.
http://acurazine.com/forums/showthread.php?t=792642
When notice it's not connected I try to connect manually through my phone and it's like it doesn't pick up the Bluetooth signal.
I'm looking for ideas on how to trouble shoot to see if it's the phone or the Handsfreelink. I tried to pairing the phone but the button on the steering wheel that you need to use to pair the phone doesn't work!
