Kia Sportage battery and electrical Problems
mlgarbinsky
Member Posts: 3
i have a 99 kia sportage. my problem is sometimes when i go to start my car i turn the key and it goes to start a little then the whole battery goes completely dead! its a new battery. and we have done battery/alternator tests i don't know whats the matter any help would be appreciated.
Interesting. This just happened to me today! I have a 99 as well just getting ready to turn 100K. I turned the key and nothing happened. I turned it again and it started. I drove about 5 miles then the engine light came on so I came home and parked it. I turned the key a few minutes later and it would not start and will not start. All dash lights are on however the starter will not engage and I hear no click. Battery is fine. I am going to check the starter later if the weather improves. I need help too:~(. Thank you in advance.
JKstorm
JKstorm
..I guess that means the alarm starts sounding when opening a door and keeps sounding even when the key is inserted in the ignition...Is your car equipped with a remote door lock? That complaint comes rather frequently but I do not remember someone coming with his solution once found out; ...
check with www.kiatechinfo.com and look for information about ETAC module..however I did not find a reset procedure..
anyway come back with your solution once the problem is resolved...
my KIA Sportage 4X4, build 2000 has an issue with the alarm system. The alarm goes on after having locked the car which can be instantly or after some time. Any thought how to fix it or at least disable the system because right now I cannot lock my car because it bothers everybody.
Thx
Frank
when i am starting it will start with huge sound and the niddle will be at around 2.
the spares parts are not available we have to search too much even with their appointed dealers...
1 after driving your car while park, leave the front passenger and driver's door open
2 shut the ignition off
3 with the ignition off, shut the passenger door
4 start the car with the drivers door open
5 close the drivers side door while the car is running
6 shut the ignition off with the two doors closed
7 exit car as normally would do
8 lock car using master lock on drivers side
CG
1) Check your "back gate open" lock. make sure it is turned all the way to the left. I know that the back gate open dash light may not be on, but this seems to be weird in mine.
2) When I th9ought the battery was dead, I went to jump it. no sooner than I connected the negative cable when the alarm went off, and the car started fine. I also noticed that the check engine light, which has been on since I bought the car, is now off. May come on again later. It did this when I had the alternator checked.
3) I am taking it to a mechanic today. I'm thinking that it has something to do with a sensor. i wish I woulda read more about the sportage before I bought it.
I'll let you know what they think, though honestly, based on what I'm reading, this car is full of boogers and spooks. No one seems to really know what the answer ever is...
I'll keep you posted!
The day I brought it home, the battery died. It goes dead at least once a week. After 3 batteries, I don't think that's the problem.
Tonight I drove it home, had dinner, went to put it in the garage, and the battery was dead. In less than an hour. 30 seconds on the charger and it started.
I have despaired of the dealership fixing it. They can not find a problem. The next time they say "you must have left the lights on" someone is going to loose a tooth.
This thing is, in fact, a piece of garbage. I don't want to trade it in because I'd feel guilty pawning it off on some other unsuspecting fool. It is pathetically underpowered, gets terrible mileage, and is generally a crap chunk.
On the other hand, my 1999 Sephia, although almost completely rusted away (I think the seat belts are the only thing holding it together) runs beautifully. I let it sit for a year (whilst swearing at this Sportage). One day, in too much of a hurry to again recharge the Sportage, I got into the Sephia, tapped the key, and away we went!.
How a car company can make something as reliable as a Sephia and then produce something like the Sportage escapes me. They stopped making the Sephia, but push the Sportage. I thought only American car companies were that stupid.
BruceR
Kathy
Where is sprayed is where I put the key in the door to lock and unlock it.
Give this a try .. I hope it helps .. Please let me know if it does... It really did the trick for me. so now i do that quite often
Towed it to a shop and the guy came out and said "It's the alternator. It will not be cheap, that's the trouble with these foreign cars, they get good gas mileage but their parts are expensive." He didn't have the part in stock, the SUV was fixed early the next day. I rented a 2004 Mitsubishi Lancer 4-dr. sedan and decided to trade the Sportage 4X4 in about 3 years later, when the 2008 Lancer GTS came out, it was in March of 2007.
We had a 5-speed standard tranny in our '01 Kia Sportage 4X4 and the SUV's locking hubs worked like a champ for us. Got of unstuck in the ice and snow about 4 times while we had the nice looking little SUV.
But that's what yours sounds like to me - the alternator.
There's no easy online answer to problems like this. It requires a methodical diagnostic from a well-qualified electronics specialist.
Here's a list from the International Automotive Technicians Network
See if there is someone on that list that works near you. They are trained to fix problems like this.
I got my 2004 Kia Sportage and never had any major issues other than reg maintenance stuff. I can drive the car locally around town during the day with no issues. But something strange is happening this few days, the car starts good, drive it around and soddenly goes off which will take about an hour before starting and sometimes start immediately but with heavy/tick smock, can`t accelerate. Sometimes i will drive for 2-3 days without going off. i have tried all no good result. I NEED YOUR HELP
