Ford Fusion/Mercury Milan Battery won't hold charge
Two Mondays in a row, I've gone out to start my car to head to work only to find a dead battery.
Last week, my local Ford dealership theorized that it was a result of corrosion. They cleaned things up, and I was able to drive the car to work on Thursday and Friday.
It's back at the dealership. In the meantime, I was wondering if anyone else has experienced anything similar. NOTE: I don't drive the car on weekends.
Did you get an answer to your question about the battery not holding a charge?
Also, it seems like places like Sam's, AutoZone, Advance Auto Parts do not carry a battery that will fit in a fusion. Any alternatives other than the dealer?
Thinking about installing a trickle charger in the engine compartment to maintain the charge if this is not covered by warranty.
Looking for someone with the same problem and what can be done about it.
A trickle charger would be a possible solution.
indicates loss of up to 2% per day, so it would seem like even starting once per month would be sufficient? Of course, then the question is how long does it need to be driven to get back up to near full charge? I'm guessing that driving once per day for 3 miles is probably more of a problem for a battery than driving once per week for 20 miles.
Maybe a charger that plugs into the cigarette lighter/accessory socket would be a fairly convenient solution?
That is good advice, but i would add that to pull more than one fuse on related circuits, if pulling one at a time doesn't work.
i.e. - on the ESP, it may be related to the ABS circuit.
- mirror heaters related to rear defogger
- if it has speed sensitive wipers or volume on the radio, then check the ECM speed sensor against the wipers and/or stereo circuits
etc
A competent dlr would know this. I would go elsewhere, then go back and tell them that a dif dlr fixed it by troubleshooting the obvious. Then I would write Ford and ask them why one dlrship was able to fix it right away, yet the other says we don't know.
I guess my patience is wearing thin with so-called mechanics and service/wty depts that are paid really really good wages (at least the dlr charges high rates of 80 to 90 an hour and more) and are educated on the very brand they work on, yet are so quick to offer the corporate excuse "we don't know where the problem is" or the other famous BP raiser..."they all do that"..
There a lot of electrical systems still active even though the car is off.
