Chevrolet Blazer Thermostat Replacement
I have a 2001 Blazer ZR2 4x4 and need to know how to replace the thermostat. Any help would be appreciated! Thanks!
To remove a thermostat for whatever reason require the following steps:
1.) Remove two bolts from the thermostat housing located at the end of the return hose (top hose) on the radiator.
2.) Pry out the old thermostat with a screwdriver.
3.), Scrape the thermostat locating lip clean on the manifold.
4.) Install the new thermostat in place of the old one.
5.) Apply some Locktite High-Tack sealer to the gasket surface of the thermostat housing.
6.) Clean the thermostat mating surface on the intake manifold.
7.) Place the thermostat gasket furnished with the new thermostat to the Loctite High-Tack sealer you applied to the thermostat housing mating surface and align the two holes in the gasket with the holes in the housing. Do not apply sealer to the manifold side of the gasket. Let the gasket set for fifteen minutes for the gasket sealer to cure. Never use silicone type sealers anywhere on an engine.
8.) Install the thermostat housing and gasket over the new thermostat.
9.) Reinstall the two bolts only finger tight to make sure they are not cross-threaded.
10.) Tighten the two bolts with a socket and ratchet wrench alternately and carefully to 24 lb. torque in 8 lb increments. .
11.) Start the engine let it warm to the operating temperture of the thermostat and look for leaks around the thermostat housing. Sometimes a minor leak will be seen for a few days until the gasket swells and seals.
12.) If a leak is seen after a few days, tighten the bolts again evenly and carefully up to 1/8 turn or a an additional 2 lb. torque. Overtightening can break the thermostat housing.
The problem may be bad heater fan motor and can be tested. If the fan motor is good, it is a kinked or a disconnected vacuum line, a disabled heater control switch or it could be that the linkage that opens the register (heater door) is disconnected. The register is located inside the heater plenum and the vacuum lines and controls are located under the dash If the fan is operable and if the register in the heater plenum does not open, warm air from the heater core cannot enter the pasenger compartment.
If the heater core has recently be replaced, the person who did that work accidentally disabled the register controls.
If both feed and return are hot, you have a baffle not operating in the duct work. Haven't worked on these before, but there are others on the maintenance and repair board that have.
Good luck,
Thanks again.
THANKS!!!!!!!!!!!!
Jim
What flush solutions work well?
The only thing I am not really sure of is where the drain plug is on the rad and how does it open.I think I found it on the passenger side but I am not sure.
Does any of this make any sense?
I am more familiar with older vehicles so this is fairly new to me.
I just changed the thermostat on my '02 a couple of days ago. I ended up pulling the top hose at the radiator and aiming it down to a bucket under the car. you will probably have to pull the cruise and throttle cables and their brackets from the throttle body to get to the back thermostat bolt. I know it looks like nuts on studs, but it is a bolt with a stud on top.
Once you get the hose off and the coolant down, the whole job takes about ten minutes.
And yep, if the thermostat is not closing fully, the engine will not warm up in the prescribed time and the light will come on with a P0128 code set.
I have recently ran into a temperature problems with my 2000 Blazer. I recently replaced the heater core in May of 08. So I don’t think that is the problem. My Blazer still blows warm but not hot air, and the defrost works but not the best.
My temperature gage flocculates from normal of just under 210 to almost over heating, but as soon as it gets close to that point it shoots back to the cooler side (This happens when driving). The Blazer is going through a gallon of Antifreeze every two too two and half weeks. I have not noticed any leaks coming from the engine.
Any suggestions on what it could be would be helpful.
I am mechanically challenged, and am not to sure what the problem could be. I would like to solve it before it grows to a bigger more expensive ordeal.
I checked the overflow tank it does not seemed to be cracked.
Could the Blazer be burning that much antifreeze if a sensor is off, or if the water pump is not working right?
You side it could be filling the crankcase; that would be the part of the engine with piston which gives the car its power from, right? And if that is the case, it sounds like an expensive job?
When I asked the guy to give more details on the items that it had said, it did not seem like he knew what he was talking about.
Here is some of the things that were listed,
P0101:
1.Vacuum hose off
2.Throttle body intake tube loose, cracked or off
3.BARO (Barometer)/ MAP Manifold Absolute Pressure defective
4.VAF (Vane Air Flow) MAF (Mass Air Flow) sensor dirty or defective.
P0420:
1. Catalytic Converter defective Do to possiably to 2, 3, or 4.
2. Engine misfire or running condition
3. Large Vacuum leak
4. Engine oil leakage into exhust-valve guide seals piston rings.
The guy at Autozone said I should try and do the vacuum leak first cause it showed up on both of them. Now, to me,he did not know what he was talking about, so i want to make sure before undertaking this ordeal it is handled the right way the first time.
If any of those could be linked to the leakeage of antifreeze and the heat not working, could you let me know. : ) Thanks car guys.
Intake manifold gasket failure is somewhat common on high mileage 4.3L engines.
