BMW 3-Series Ride Quality
I have a 2008 335i with sports package. The highways I commute on are poorly maintained. The car will throw me an inch or two into the air if I hit a small bump @65MPH. It also follows groves in the road if I don't hold the wheel tightly. Lastly, undulations in the road (to help water runoff) cause the car to vibrate.
I assume I am not the only one to experience this. Has anyone found a fix (e.g., new tires, suspension upgrade, etc.)?
Also, check your inflation pressures. They may be way high (which the clever little sensors don't care about).
There is a whole discussion of run-flats on here, and tramlining (following grooves in the road) is one of several bad traits. The consensus is that real (get-flat) tires fix the majority of this.
Best regards,
Shipo
Think I have seen you on e90post or another BMW forum :-)
Anyways I have a 2008 335xi Coupe with Sports Package and 18" wheel upgrade that had the Bridgestone Potenzas mounted from the factory.
Just recently I mounted 17" BMW alloy wheels with Michelin Primacy Alpin PA3 winter RFTs.
The MIchelins are definitely an improvement over the Potenzas in terns of ride characteristics over rough surfaces even though they are high performance winters. Its not like the Potenzas produce a bad ride on all road surfaces but they can produce a "thump" when hitting a road bump the "wrong" way.
That said it seems like Michelin just does a MUCH better job of engineering an RFT with much better ride compliance than the competition. In fact BMW thinks so as well since it is shipping Michelin PS/2 RFTs on some 2009 3-series.
So if I was going to replace the Potenzas for Summer+ use I would buy the Michelin PS/2s in a second.
Now I am looking for new tires. I want to stay in my seat, reduce vibration, and minimize tramlining without significantlly compromising performance. After reading the recommendations above and in other threads, I am still not sure what to do. I am reluctant to fork over more than a grand for another set of tires unless it is reasonably sure to fix the problem.
The most recommended tire appears to be the Michelin Sport PS2 (I am not sure if this is the same as the PS/2 referred to above. I thought the PS2 was a GFT). Has anyone tried this tire on a 2008 335i Sport, and how did this impact the ride? Are there other tires multiple people have used to good effect (i.e., Yokohama AVANT S4)?
If I replace the RFT's will it impact the oil cooler in the wheel well? What about the tire pressure sensors?
They are available for the 18" staggered Style 189 wheels that come with 335xi Sports Package + the 18" wheel upgrade. Looks like this would set you back at least $1,500 installed on your current wheels. Now that is the real price of owning one of these cars.
Don't cripple the dynamics of your 3-series from the get go by ordering the soft suspension. Just put normal tires on it.
If the BMW is still too stiff for you, then maybe a Buick or Mercedes is a better choice.
Toyota or Ford for me next time.
Between us my wife and I have had 2 C Class Mercedes, both of which were very uncomfortable and riddled with electrical and computer faults, (13 times in 2 years) a new 2009 Audi A4 which spent more time in the shop than on the road due to steering rack problems (shudder) and continuously stalling and which got traded on the BMW, which I grant is good apart from the ride. Our only other experience was with a Peugeot that we bought as a second car (are they sold in the States? hope not !) 2007 new car, transmission packed up on the way home from the dealers. Gave us another new car. That one spent 15 weeks in the workshop over 9 months period with transmission, computer and oil leak problems. Peugeot took it back finally. I guess I'm too old for adventure now, wondering if it will start and go OK each morning. I just want a comfortable car that goes well, can be repaired by the dealer if necessary and doesn't cost an arm and a leg like the Chev and Fords, Dodges etc that I grew up with. You do have a point about the drivability I admit.
