Lincoln LS Engine light
Hi everyone im new here and was hoping you all could help me. I have a 2000 LS with 62,000 miles on it and the engine light just came on, i was idling in park and it cut off on me and the idle is starting to get a little ruff, it doesnt cut off while imm just sittin in drive but feels like it wants to cut off while im in park. what could this be?
We are having the same problem with our 2003 LS. The check engine light is on and the other day, we heard something pop and it would not accelerate past 5 miles per our. We pulled over and it keep stopping as if it were going to flood and out and after about a half hour or so, we eventually picked up speed and were able to make it home. Yesterday, it went dead as I was turning and I stopped. I attempted to restart it and it sounded as if it were going to flood out, but eventually it started and I was able to get it home again. I also smelled gasoline yesterday when I was trying to restart it. What is the problem and is it an expensive fix? :sick:
buckeye68
P.S. I do take my car for routine oil changes (high milage), change my air filter every 6 to 8 months depending how dirty and check all fluids. Also heard coils fail a lot in LS due to gaskets failures since water or oil seeps in and shorts the coil (manufacturing problem).
That said, $3400 sounds awfully high. How much are the cats?
My engine light came on. I had codes read. PO304 is the code. Mechanic said that the "Valve Guide Seals are Leaking" and there is oil on the pistons. He isn't sure if he needs to remove the heads to repair this. Estimate is $1200.00. I need some help from someone! Would this be under any kind of warranty?
6 hrs labor - 270
gasket sets (from Ford) - 220
Transmission - 50
Spark Plugs - 60
PCV - 8
Fuel Filter - 20
10 qts trans fluid - 42
oil change with Mobil 1 - 40
Total - 710
I told him to go ahead because I don't know what else to do.
Thanks for your reply
But light is solid on (light went out after COP's replaced and came back 7 days later). I will try to replace 02 sensors before I spend $$ on converters. If I do have to replace them Autozone sells universal cats only but I was wondering if V8 2005 LS direct fit cat assembly fit an V6 2005 LS. Seems to be the only one that is sold online, no V6 direct assemblies on any website of any kind.
