I encourage everyone here to file a complaint with the NHTSA - it only takes a few minutes and it might force Chrysler to actually do something about this issue. Maybe a class action lawsuit would do the same.
Again - here is the link to file a complaint with the NHTSA:
http://www-odi.nhtsa.dot.gov/
Is the brake problems with the 2008 and later years really that widespread, or are we just hearing from those who are having unresolved problems?
On our recent trip to Florida, the right front started making loud "crunching" type noise with a sharp right or left turn. Took it to an Orlando dealer and found the "drive axle" needed replacement. Dealer says we were lucky, "they usually don't make noise - they fall off". They had the part in stock (it's a popular part) and started right at it. While working on that they had anti-freeze drip on them. Found the water pump was leaking - so they changed that. Then they gave me a "23 point free inspection" and told me to see my dealer when I get back to Cleveland. The rack and pinion was seeping and the power steering fluid was burnt - signifying the internal of the rack was under stress. Chrysler extended warranty won't allow a change out until there is an actual leak - seeping don't count. He said it has to be watched - it will fail. I find it hard to believe that a van with 50,300 miles could have so many problems. My other vans surpassed 150,000 miles with fewer problems. I'm thankful that I bought the extended warranty - and pray that Chrysler continues to honor it and the lifetime warranty for the engine / drivetrain.
Seems to me that Daimler squeezed every penny out of Chrysler and didn't give a damn about quality. This is my 4th Chrysler mini-van and by far the worst. It looks good but the quality is gone. I bought this as I entered retirement - this would be the last vehicle we would purchase. What a piece of junk. Very disappointing!
previously 96 Voyageur
Same problem as everyone life expectancy is vey short and apparently very profitable. That is until their out of business.
Find a reputible independent and dont use OEM.
However, after reading the other posts from owners in similar situations, and getting nowhere with the dealer, my wife spoke at length to Chrysler corporate and we had to pay "only" $250 for replacement. Somehow she remained calm on the phone with the rep -- I would have not been so kind...
I am fine having to replace brakes around 30/40/50K but not every year. Who knows how long this $250 "deductible" will be around. Throw in a previous AC/fan blower failure @ 13K and I don't want any more to do with this car, even though we purchased in January.
This past weekend, we traded in the vehicle and are switching brands. Sorry Chrysler -- we tried.
I got a trade-in value of $12K. I probably could have pushed to get $13K (KBB value) but I was able to get the purchase price of the replacement vehicle down to what I though was fair, and then some. Also there was some minor panel damage to the rear fender and door. I did not shop around a lot either -- honestly, I just wanted to be rid of it.
Also I changed brands (Toyota) so I didn't expect to get as much as staying w/ Chrysler. Given the problems we had, that was fine by me.
Can you give us a number or tell us who your wife spoke to in Chrysler 'corprorate or how she got there? ' Seems like most get sent to a call center in India where its impossible to make any progress.
Congrats on moving on - I'm jealous. I'm pretty sure I owe alot more than the car is worth, which makes me even more annoyed.. I can't believe I bought this car brand new....from Chrysler no less. What was I thinking?
She called 800-992-1997 and patiently worked with the rep. Probably depends on which rep you get and how sympathetic they are (or aren't).
Thank you Diamler. Thank you Cerberus. Thank you taxpayers. I'm sure Fiat will fix the quality problems.
Next stop: NHTSA site to register a complaint.
Unbelievable.
Will it hout to put semi metallic pads on with new rotors?
Pushing 28,000 miles on this '08 and this is at least the 4th time the rotors have needed to be replaced or resurfaced. The last repair they did were with "updated" rotors and pads that "should solve the problem." Well, this time the pads are actually OK but the rotors are shot.
I've contacted an attorney and will be starting the process to try and get this van bought back. It's quite unfortunate, my wife LOVES her van and would like to keep it forever, but not if we have to have the brakes done 1-2 times a year.
For those of you NOT wanting to try going this route, there is a company called Frozen Rotors that makes a great product and they do have rotors for the 08 Caravan. The reason I'm not going to try that is because I'm not 100% sure it will cure the problem and by doing so I likely lose my chance to file a lemon law suit since the parts on the van would then be aftermarket.
http://www.ehow.com/about_5463667_metallic-vs-ceramic-brake-pads.html
I would check with some other stores to get ceramics.
I'll be doing the replacement myself, with top of the line parts from NAPA costing a little over $200.
The thing I found strange is how deep the pads had worn into the rotors (even though there's no metal to metal contact yet). Way beyond the ability to resurface them. In the past, you could usually get the rotors resurfaced, allowing them to be used with a second set of pads.
One thing the parts guy told me was that the manufacturers used to source brake rotors from US based foundries, but have now switched mostly to Chinese foundries. Unfortunately all the aftermarket rotors they had available come from China as well. Not sure if that's really true or not - but these rotors surely look like a much softer material than in the past. (And if you use a softer rotor, you're forced to use a softer pad to prevent eating them up too fast. And soft rotors + soft pads = frequent brake jobs.)
Have a good day and good luck to you.
Have a good day and good luck to you . . .
Please see my post #75 with an update to our situation.
Have a good day and best of luck to you.
I'm still not comfortable with the outcome and am concerned about the future. We will take the car to the dealer from now on though in case we need to write Chrysler again . . .
Bottom line in conversations that I have had, it sounds like the rotors they put on this vehicle are not large enough to handle the weight of the van. I called the 1-800-992-1997 Chrysler Cust. Serv. number offered on another post (thank you!)...I will also file a complaint NHTSA listed in this forum of postings.
I just seeked out this forum today because I did not think what was happening to my brakes was normal and wanted to see if others were having the same problem. Clearly you are. Thank you all for your input. Hopefully they will do a recall soon and upgrade the rotors on all of our vehicles! We have to do our part and complain...
We would BOTH be interested knowing what we can do as we ALSO live in ONTARIO, CANADA.
My wife and I debated whether or not to just throw aftermarket rotors and pads on there and hope for the best or just give up and lemon law since we can't do both.
Anyway, as posted before, we decided to go the lemon law route. Been about a month since the filing, no updates yet.
Long story short, the manager came out to talk to me. He asked for my story and said "we have seen a lot of T&C with brake problems so I am going to authorize, under warranty, to replace not only the rotors but the brake pads." He is giving me back the pads that we just replaced in Sept. so I can use them in the future (hopefully not too near future). I got a call tonight from the dealer because I was having problems with the gear shifter (started Saturday after I made the appointment-lucky, I guess) and he said he had to order a whole new gear shift assembly so I would have to wait until Wednesday to get it back. They gave me a loaner so it is ok but when you are used to this with 3 kids, a Corolla just doesn't cut it. Ugh.
That makes brake pads and rotors, gear shift assembly and back auto door actuator that have been replaced.
So, be persistent. They know there is a problem but they don't give in easily. Like I told my dealership, I bought a NEW Chrysler so I didn't have to worry about safety or repairs but I am afraid to drive it with brakes like this. We paid good $$ for these vans and shouldn't be having these problems. I am writing Chrysler to tell them that my dealership fixed their faulty product. Maybe if enough of them are reported they will do a recall.
Needless to say It really is not the dealerships fault but I blame Chrysler. I called them and pretty much got the "well, the warranty is 12 mos. or 12K, I'm sorry, but I'm not buying it!! I think I'm going to the Attorney General here in CT, and maybe even farther. Imagine how many people do not realize THIS IS NOT NORMAL. I would like to see Chrysler build or buy a better quality product that will last at least 36,000. I paid alot of money for my new van so I would not have to worry about this kind of nonsense so soon. Please, I plead with everyone who has this same complaint to take it as far as you can. Don't let the "customer service" at Chrysler just tell you nothing can be done, take it as far as you can. There is strength in numbers people, this is America. We can build a car that lasts 100,000 miles, but rotors and pads only last 13K to 20 K, that's just bologna and we all know it!! :mad:
Took the van in for it's regular oil change and aske them to inspect the brakes because they were squeaking again and uneven. We had the pads replaced at 12K miles because they were worn down to metal and was assured that the replacements were better than the pads applied on assembly.
the Tech came out and we discussed how not only were the pads gone the roters were also beyond machining and needed to be replaced as well - 21,000 miles and I have to replace the pads again and replace the rotors entirely. I actually asked if they were made of plastic.
When I asked the tech and the service department manager about this shey both kind of shrugged, and attempted to explain to me that on this van this wear and tear is normal and expected. I called BS on this and asked if the rotors and pads were made of plastic.
What's worse is when I asked whether the pads and rotors they were replacing the crappy ones with were any better, or if I'd have to plan on replacing them again in less than 20k miles, they shrugged and repeated that this is expected wear on these vans.
The consensus is that this wear and tear is absolutely, completely and without exception not expected - there is not a single person looking to buy, lease or borrow a car or van that would have ANY sort of reasonable expectation that they will be replacing pads every 12K miles, or that they would have to replace the rotors after 20k miles.
At approx $400 per incident, this flies in the face of reasonable expenses for maintenance of a vehicle. Is there any resolution available for this? Any avenue for being made whole for being sold a POS without disclosure??? Any attempt on the part of this company to address what is clearly a defective vehicle issue, with safety implications??
My biggest prob is I'm going to have the rotors turned and pads replaced, for a few hundred dollars, and what will happen in another 20,000miles. I also hate people asking me if I am hard on my brakes!! Come on people if everyone is having the same prob and we all drive differently I highly doubt it's our driving!!
