Dodge Dakota Body Problems
95_Dakota_Joe
Member Posts: 2
in Dodge
Have a 95 Dakota when you left the driver door latch the door doesn't open. Put in the shop and they say the plastic clip that holds the rod has completely broke up. To fix this issue they will need to remove the driver side window first. To do this they will need to drill out the pop rivets that hold the window in place. Does this sound correct?
Bert
Can I just replace the cable? Do I need to replace the regulator? Is the cable built in to this?
Thanks, Brent
If your Dakota is like my Caravan, then the cable assembly can be removed from the motor (it bolts to the motor housing with 3 bolts). But, you would have to go to a junk yard, pull the cable assembly or entire regulator from something there, and then replace just the cable assembly. I do not think you can buy just the cable assy from Dodge or anyone else.
Again, thanks, Brent
THANX
door with a jimmy bar. They bent the rod and broke off the plastic clip.
I called the stealership and they wanted over $300 for the parts including
a new lock! I decided to repair it myself. Removed the inner door panel and
just raised the window up and I was able to get at the rod. I also drilled a
hole in it and inserted a very thin stiff wire..or maybe it was one side of a
thin cotter pin, but the lock works and I saved myself $300 in the process.
