Nissan Sentra Rear Alignment Problem
i recently noticed the unusual wear on the rear tires. i had it checked with a local tire shop and got the confirmation that the rear alignment is off and there are no adjustments possible (like trailer tires). i brought it to a nissan dealer and confirmed the same thing. however, the dealer indicated that there are no service bulletins and that there is no fix for the issue. i am in contact with the service manager, but it seems like it is going nowhere. from our last conversation, there are shims that can be used but considered aftermarked therefore not under warranty. i insisted at all times that this is a defect and should be covered. i will pursue this with nissan consumer affairs (even the dealer suggest the option) and bbb if necessary.
anyone with a similar situation here? this is a problem that takes time to be visible on the tires. in my case, the car always drives perfect and i did not notice the issue until about 20k miles later.
since there are similar postings on the net about this specific sentra issue, any 07+ owners or potential used sentra buyers, get an alignment check if you can. thanks.
i did bring my tire pro's reading initially and my nissan dealer did their own to verify the issue. when i called nissan consumer affairs, i insist that this is a defect. the process went well, not counting the phone tags. after approval, nissan authorized the local dealer to replace the whole rear assembly.
i advise you to go ahead and get your dealer to check alignment then contact consumer affairs if needed. dont wait til you have more uneveness on your tire wear. let me know if you need more info.
How can this problem be fixed? With a rear axle replacement and/or shims?
Do you think I can get Nissan to do it? Who can I contact?
1 use shims
2 Replace the rear end
I would push for a new rear end if it was my car and see if Tires Plus would back you up.. In any case get it on record before the warranty runs out.Start out nice with the dealer because if you go in with big guns drawn, there is no where else to go.Also see if your state has a lemon law and keep us informed.
Corkscrew
This guy invented a method to straighten fixed axles, he is good.
Darin Nishimura is highly regarded in the Sentra high performance community !!
http://www.nissanperformancemag.com/november01/westend.shtml
http://www.nissanperformancemag.com/may03/handle_this2/
http://www.b15sentra.net/forums/showthread.php?t=132494
