Considering 2000 Outback but REALLY worried about HG
My college age son really wants to get an Outback but these HG issues have me very spooked that it will drain his bank account.
I've looked at and inspected between 5 and 10 cars at dealerships and small resellers. All had HG issues. I've a private owner with a 2000 Outback. It has 75K miles, manual tranny, garage kept, one owner who has all of the records. All of the recall work has been done. But after reading all of the HG issues, catalytic converter problems, clutch replacements I'm thinking a Honda CRV might be a safer bet.
Can anyone tell me how wide spread these issues are. This car will be used by a college student who needs reliable transportation to and from school (200 miles away). He can't afford to get into a vehicle that is going to cost him in repairs. However, he doesn't want to consider anything but a Subaru.
I would really appreciate some perspective on this.
Lynne
Lynne
So, now I ask, was the coolant treatment added at any point in the past? If the car is solid now, with no clutch judder, no gasket leaks or other leaks, and no CV boot or brake issues, you are probably going to be in good shape for a while. Not sure how many miles the child will be putting on the car, but in another 30,000, it will be due for a major maintenance including a timing belt change. Plan for it, set aside some funds for maintenance, and the car will be rewarding.
If you keep up with the coolant additive, it will help reduce the chances of a leak taking hold.
Joe
I reviewed the service records, no check engine light issues, no knock sensor or O2 sensor issues. Head gaskets are still good (at least for now). Clutch feels solid, no shudder. Of course, now that my son is learning how to drive a stick we may need to replace the clutch sooner than anticipated.
We may have head gasket issues at some point, but I think we have plenty of time to save for that. Overall, I couldn't be happier with car.
Thanks again for your input!
Lynne
No car is perfect, the CR-V had engine fire issues when gen II came out, 2004 IIRC?
In addition to the head gaskets, I have also had a major transmission leak - complete gasket job bill was about $600 - and it shows a small leak again. Repair was done about 25,000 miles ago.
Would I buy another? No - I had a 92, previously, and only replaced the speedometer cable on it - this one has been a different story.
We had the extended warranty and never used it!
At least that helped sell the car.
I did that once, and it was the longest 1200 miles I ever drove! :surprise:
Aside from design issues, you need to have your system checked out. It could be fluid related, glazed pads, a frozen caliper, trashed rotors, etc.
