2008 Nissan Quest squeaks and rattles coming from sliding doors
I bought a used 2008 Nissan Quest base model with 20800 miles and it runs really well except that there is a squeaking and rattling noise coming from the sliding doors. The noise comes up when I hit road bumps or rough roads. My friend has the same vehicle but his unit does not have this annoying noise. I brought the van to a Nissan dealership and they just put some lubricants on the rubber strip but they said it is a usual problem with the Quest and the lubricant will not really eliminate the noise.
Anyone who has the same experience? Can someone tell me how to get rid of the noise? Do I need to replace the rubber stip?
Thanks and I really appreciate it if someones answers back.
Before you bring it back in, make sure you don't have anything in the tracks. Be persistent.
If you happen to have your problem fixed, please kindly inform me too.
What they did according to the work order:
"Test drove the vehicle found right rear door rattle and right rear door finisher panel rattle. Also water sound coming from rear of vehicle.
Adjusted passenger rear sliding door roller. Test drove door noise fixed at this time. Trim panel noise still remained removed passenger rear sliding door trim panel and install foam between door and panel. Test drove no more noise from door panel after installing foam. Noise from rear of vehicle still present found water on rear bumper braice (?) removed rear bumper cover removed water test drove no more noise at this time."
I hope this will give you some hope that you door rattle will be fixed. If you happen to be in Michigan in suburb of Detroit, go to Nissan Bill Cook in Farmington Hills. I had a good experience, and I will come back again if I need to (but, I hope I don't have to).
I will inform you of the outcome. Thanks again.
I've heard of people using a can of expanding foam from the big box hardware stores to pop out small dents (and people have probably popped some welds or dented their sheet metal playing with that stuff to).
You have two options: try another dealership or call Nissan Consumer Affairs (owner's manual). The dealer should at least make an attempt to fix the problem.
I got a used 04 Quest even though I knew about these problems as it was a screaming deal and I needed a minivan and it was not my primary vehicle.A new Quest -- No way.
I know this may be a radical solution-but if possible ,trade it in if the hit is not that much.Because with time it depreciates horribly.Trade it in and get a used or if possible Certified Sienna or Odyssey.My preference would be Sienna-quiet,plush and smooth ride and excellent reliability.Again its your decision-if you can live with all those rattles and shakes/vibrations and the brake problems,its your call.But this would be my personal advice.Just MHO.Good luck.Keep us posted.
I agree that you need to call the consumer's affairs and complain about the issues - I think the dealership should at least try to fix it (heck yeah, they are getting paid by Nissan to do this - extra business for them). My understanding is that the consumer's affair will contact the dealership directly if you cannot resolve it between you and the dealer.
My Quest is going strong, and I have no regrets in buying it in cash.
