Hyundai Elantra Brake Problems
Bad08Sonata
Member Posts: 25
in Hyundai
Immediate Attention.....All Hyundai owners should check to see if their Emergency/Parking brakes work correctly.
All vehicles made after 2006, all Hyundai models, with the pull lever type of Emergency/Parking brake assemblies should be checked to see that their Emergency/Parking brakes work correctly.
Additionally, if you have had any rear brake work done on your vehicle that required removing the rear rotors or emergency/parking brake work done; more than likely...the service technicians did not repair it correctly...not repairing or making adjustments to your vehicle according to Hyundai Official Repair/Service manuals.
Apparently, someone dropped the ball at Hyundai Motor America and did not place a requirement for a force push/pull gauge on the Hyundai service departments.
Bottom line...all levels and all certifications of Service Techs, Field Service Engineers and Hyundai Representative do not have the necessary tools on-hand to perform EMERGENCY / PARKING BRAKE INSPECTION AND ADJUSTMENT PROCEDURES CORRECTLY, SO THEY SKIP THE OFFICIAL PROCEDURES.
Skipping these procedures could lead to emergency/parking brake drag when the brake lever is not set or the parking brake not functioning when you believe you have set the emergency/parking brake.
Step 1. Block the front tires so the vehicle will not roll.
Step 2. Raise the vehicle as if you were going to change the driver’s side rear tire.
Step 3. Rotate driver’s side tire while the brake is in the released position. If you feel any drag or hear a rubbing noise, your emergency/parking brake may be dragging. If you suspect dragging, lift the emergency/parking brake lever 1 click, if the drag feeling has intensified or you cannot move the wheel, then your emergency/parking brakes need to be adjusted.
Repeat the above steps on the passenger’s side rear tire.
Now that you know your emergency/parking brakes are not dragging, check to see if the emergency/parking brake will hold the vehicle.
Step 1. While a driver is in the vehicle, release the emergency/parking brake lever.
Step 2. Pull the emergency/parking brake lever up 4 clicks from the released position. Be prepared to step on your normal brakes...Place the vehicle in drive...at idle speed...
Does the vehicle move?
If YES, Repeat the above step with the lever pulled up an additional click each time until you reach 8 clicks from the released position.
Make note when the emergency/parking brake actually holds the vehicle.
If your emergency/parking brakes do not hold the car when the lever is pulled 8 clicks from the released position (where the adjustment is check according to the official manuals and around 44 LBs of pull force maximum is need to raise the lever 8 clicks), then your emergency/parking brake is not adjusted correctly.
When you take your vehicle in to have your emergency/parking brakes adjusted...ask that you be allowed to see the technician use a force push/pull gauge during the inspection/adjustment procedures.
Additionally, if you identify a problem...please email Hyundai Motor America customer service at ConsumerAffairs@hmausa.com and have them document your issue...have them give you a case number.... this is the only way a TSB or recall will be issued, since the servicing departments are skipping the official inspection steps.
Good luck
Good luck
Also, there are several Hyundai models (Accent, Azera, Sonata, Tiburon, Tuscon at least) for which the current design dates back before 2007. Wouldn't these cars be affected by your warning also? (Unless of course Hyundai made a general design change to all of their parking brakes starting with 2007 models.)
Also, could you please share with us how you know that it is likely that all Hyundai service techs do not repair parking brakes correctly and that no Hyundai dealer service departments have the necessary tools to perform parking brake inspections and adjustments? Because if that is the case, it won't help Elantra owners like me and other Hyundai owners to bring their vehicles into a Hyundai dealer to have the parking brake worked on. They would need to go someplace else, right?
It is specific to some 2006 and later, because this tool is used to inspect, adjust and repair the emergency brake. OWNERS SHOULD CHECK THEIR ON-LINE MANUAL FOR THE EXACT DETAILS.
Why they do not have the tool, look at the ESSENTIAL SERVICE TOOL SURVEY FOR 2008 (on line) not a listing for a force push/pull gauge anywhere. So this tool was not on the suggested tools or placed on requirement for servicing dealers.
The dealer has the official manuals and everyone that uses this forum could review their official inspection/ adjustment/repair procedures.
I challenge you to call any authorized Hyundia service department within your local area and ask them how they would check the emergency brakes on a 2009 Sonata. (A new car that has several requirements for the use of a force push/pull gauge).... When the say, they would put the vehicle in drive with the emergency brake on and if it holds the car, then it works... Ask them WHY they don't follow the official manual?
I SUSPECT THEIR ANSWER WILL BE... WE HAVE ALWAYS DONE IT THAT WAY IN THE PAST, WHICH ONLY PROVES MY POINT.
How do I know this; from experience, A PLATINUM TECH, A REGIONAL SERVICE MANAGER AND A FACTORY FIELD ENGINEER ignored these procedures again (last attempt,#9, to fix my brake issues) and then started back stepping to protect their jobs.... its BBB Auto line time for me, I done with Hyundai.
As for a warranty, WHAT GOOD IS IT IF NO ONE FOLLOWS THE OFFICIAL INSPECTION AND REPAIR PROCEDURES.
As for who should work on your car, I would only suggest the dealer (under warranty) and only if you are allowed to watch them follow the official procedures....most people do not want to do this....SO I WOULD SAY SOMEONE WHO IS AUTHORIZED AND SOMEONE YOU TRUST.
Backy, I have a question for you ...I read somewhere on forum that you have driven several Hyundais over the past 3 years, I think more than a dozen... How are you able to drive so many different Hyundais?
What model and year Hyundai you own?
Print out the official inspection procedures before you go, then you'll have everything in writing and no one can tap dance around your issue.
I am not sure where to find an "online manual" with details on inspecting, adjusting, and repairing the parking brake on my Elantra. If you happen to know such a link, could you please post it? I don't think that level of detail is in my hardcopy owner's manual, but I don't have access to it right now.
I do know that my local Hyundai dealer, where I have the car serviced, prohibits customers from being in the service area, as a safety issue. Actually, every car repair shop I've been in in recent years has the same policy. So I don't think I would be allowed to watch a service tech work on the car. But since my Hyundai isn't affected by your warning, it's a moot point for me. As for going to someone who is "authorized" to work on a Hyundai's parking brake... I was not aware any authorization was necessary.
As for how many Hyundais I've driven over the past 3 years, I think you are referring to a recent post where I said I have driven about 15 (lost count after 12) 2006-9 Sonatas. Most of those were rentals. Others were test drives; over the past few years I've had the Sonata in my sights as a car to purchase. Have come very close to pulling the trigger a couple of times, and in fact I plan to check out some low-miles 2008 Sonatas with really good Internet pricing this Wednesday, the last day of the year, and see how much the sellers are willing to deal.
They are in the Official Service/Repair manuals. (about $200 for the set)
or free through the HMA Service
Here is the Online procedures for 2007
http://www.hmaservice.com/viewer/content.asp?vehicletype=Passenger&mfrcode=HY&ar- ea=HMA&langcode=ENG&modelid=HD13&modelyr=2007&mmctype=en&mmcid=25&group=SHOP&vie- wtype=&cat1=2007+%3E+G+2%2E0+CVVT&contentssize=655&firstnodedesc=Brake+System&si- tinfolist=41%5E4120%5E41200600%5Enone%5E801%5E1%5EENG%5EHY%5EHD13%5E2007%5Eall%5- E0%5Enone%5Enone%5Enone%5Eshop%5E%2441%5E4120%5E41200600%5Enone%5E801%5E8%5EENG%- 5EHY%5EHD13%5E2007%5Eall%5E0%5Enone%5Enone%5Enone%5Eshop%5E%2441%5E4120%5E412006- 00%5Enone%5E801%5E4%5EENG%5EHY%5EHD13%5E2007%5Eall%5E0%5Enone%5Enone%5Enone%5Esh- op%5E%24
You may have to signup for an account.
If the service departments are ignoring this, what other things are they ignoring...I thought an emergency / parking brake problem would be easy to fix. Well, if you follow the procedures, IT SHOULD BE.
On several models, the servicing dealer could perform the check in the parking lot if they had a push/pull force gauge.
Parking brake lever stroke
As for drag...raise each side and check for drag as I stated eariler.
You would think a new car owner would not have to double check this, something checked at the factory and again during the pre-inspection. I know, I have someones initials that indicated this was checked.
Additionally, I have several other initials or their numbers on service work orders....BUT HOW WAS IT CHECKED OR FIXED AND WHAT PROCEDURES WERE USED?
I hope you get a good 08 if you pull the trigger.
I hope you get the deal of a lifetime and it works out for you.
Keep in mind also that EVERY used car has seen a plunge in value recently, especially over the past 2-3 months. From the prices I've been seeing, the drop is about 15-20%. A few months ago, you could have probably gotten at least $2000-3000 more for that 2008 Sonata on trade-in. That's good news for people buying cars, but bad news for those selling them. The other thing about used 2008 Sonatas is that I4 ATs could be had for under $15k when new, which doesn't exactly help their resale value now.
If I don't get a great deal this week, I'll just wait until next year. I am in no hurry. I might wait until late next year, when used 2009 Sonatas will be available in volume.
But meanwhile, my 2004 Elantra is running great, 4-wheel disc brakes with ABS work great (including parking brake) and my son appreciates having a good car to take to school, practice etc.
Also, I just noticed everyone...even though hubby's car was fixed in July (fuel pump) as I looked over our bills I was getting in order, I noticed when he did his oil change in Sept like I did that they replaced his whole fuel pump and assembly AGAIN under recall. Now, makes me wonder what they did in July. The bill in July said fuel pump replaced. And the bill in Sept says Fuel Pump Kit Pump Kit installed under recall warranty.
Component Location
http://www.hmaservice.com/viewer/content.asp?vehicletype=Passenger&mfrcode=HY&ar- ea=HMA&langcode=ENG&modelid=HD13&modelyr=2008&mmctype=en&mmcid=25&group=SHOP&vie- wtype=&cat1=2008+%3E+G+2%2E0+CVVT&contentssize=655&firstnodedesc=Brake+System&si- tinfolist=41%5E4120
Repair procedures
I would print these out and ask that you be allowed to observe the tech when he or she makes your adjustments.
Additionally, I would have them pull both of your rear rotors a let you see the wear on your parking/emergency brake pads (compare them to a new set, I could not find the specs on these), next have them check the round-out / run out of the rotors and the emergency brake area contact area.
HAVE THEM SHOW YOU THE SPECS IN THE REPAIR MANUAL.
IF Rear brake disc thickness (rotors) less than 8.4 mm ( 0.33 in), have them replace the rotors.
IF Rear brake disc round out /run out is greater than 0.05 mm (0.0020 in), this includes the parking brake contact area... tell them you want both rotors replaced, your car is NEW.
20k is about 44 lbs of pull force and your lever should come up 7 clicks. Ask to see the push/pull gauge they are going to use and when they can not produce it... tell them to go and buy a digital fish scale at Walmart to get the adjustment close and you'll be back in a week when they have the right tool...... Or better yet, just keep the loaner they give you until they prove they are following the procedures.
A really good push/pull gauge is only about $300.00 and they will probably have to order it.
Imagine if someone dropped the ball on a requirement for a torque wrench... these cars would be falling apart all over our highways.
Good Luck
Components
http://www.hmaservice.com/viewer/content.asp?vehicletype=Passenger&mfrcode=HY&ar- - ea=HMA&langcode=ENG&modelid=HD13&modelyr=2008&mmctype=en&mmcid=25&group=SHOP&vie- - wtype=&cat1=2008+%3E+G+2%2E0+CVVT&contentssize=655&firstnodedesc=Brake+System&si- - tinfolist=41%5E4120%5E41200600%5Enone%5E401%5E2%5EENG%5EHY%5EHD13%5E2008%5Eall%5- - E0%5Enone%5Enone%5Enone%5Eshop%5E%2441%5E4120%5E41200600%5Enone%5E401%5E1%5EENG%- - 5EHY%5EHD13%5E2008%5Eall%5E0%5Enone%5Enone%5Enone%5Eshop%5E%24
Procedures
http://www.hmaservice.com/viewer/content.asp?vehicletype=Passenger&mfrcode=HY&ar- - ea=HMA&langcode=ENG&modelid=HD13&modelyr=2008&mmctype=en&mmcid=25&group=SHOP&vie- - wtype=&cat1=2008+%3E+G+2%2E0+CVVT&contentssize=655&firstnodedesc=Brake+System&si- - tinfolist=41%5E4120%5E41200600%5Enone%5E801%5E1%5EENG%5EHY%5EHD13%5E2008%5Eall%5- - E0%5Enone%5Enone%5Enone%5Eshop%5E%2441%5E4120%5E41200600%5Enone%5E801%5E8%5EENG%- - 5EHY%5EHD13%5E2008%5Eall%5E0%5Enone%5Enone%5Enone%5Eshop%5E%2441%5E4120%5E412006- - 00%5Enone%5E801%5E4%5EENG%5EHY%5EHD13%5E2008%5Eall%5E0%5Enone%5Enone%5Enone%5Esh- - op%5E%24
link to setup an account and login
Lastly the 20K of force should be 20Kg of force... which is equal to about 44 Lbs. of pull force.
The new 2009 Sonata procedures have the techs use a pull gauge during several step of the parking brake adjustments, with different pull force requirements... even used to establish a parking brake drag point on the rotors (then the parking brake shoes are backed off (shoe clearance).
But the procedures you posted mention nothing about requiring the use of a push/pull gauge when servicing the parking brake. So I am puzzled why you seem upset that at least some Hyundai dealers (such as the one you took your Sonata to for service) don't have one.
look at # 3 of the Parking Brake Lever Stroke Adjustment
between the yellow-orange lines
Parking brake lever stroke :
7 clicks (Pull the lever with 20kg)
BIG NOTE IN GREEN under it :
After repairing the parking brake shoe, adjust the brake shoe clearance, and then adjust the parking brake lever stroke. (Refer to "Parking brake shoe installation")
and then the picture under this NOTE
Pull up with 196 N (20kg, 44lbs) force, within 38MM of the top ot the lever not to include the push button.
I'm off to enjoy the new years celebration, I hope you have a great one too.
Maybe the culprit here is the folks who write Hyundai's repair manuals??
Have a good celebration. I am going to stay off the icy roads and leave them to the other celebrants.
Does someone else other that Hyundai write their Official Service/Repair manuals or maintain the Hyundai Motor America Service Web-page?
Whoever wrote the manual went to a lot of trouble to identify a certain pull force requirement, (put it in 3 different types of measurement force based on scale 196N/20 kg/44 lbs) identified a certain area position on the lever itself (within 38MM of the top of the lever not to include the push button) and how far the lever is to move from the non-set position (7 clicks).
If they did not want their techs to follow this ...I wonder why they go to so much trouble to include these measurements and a picture too in their manual?
You would think a Hyundai Field Engineer with a Hyundai Motor Representative and a Platinum Service Technician (all working together, on-site) would be able to breeze through these steps... THAT IS, IF THEY FOLLOW THE MANUAL AND HAD THE TOOLS ON HAND... RIGHT?
I'm in agreement with you, the manual could be a little more detailed, but this should not be used as an excuse on anyone's part, neither should skipping the procedures because they did not have the tool on hand.
I hope you have a spectacular 2009.
Anyway, I have to take my Elantra in for an oil change and a couple of other things in the next month or so... one of those things is a parking brake adjustment, as it takes too many clicks to set now compared to when new 5 years ago. So I will be sure to ask the dealer's service tech if they employ a push/pull gauge in their adjustment procedure and let you all know what I find out.
The "weak link" ... doing it by feel it not accurate... hence that's why there is a spec of 196N/20 Kg/44Lbs for these newer hyundai vehicles.
One techs feels right, might be over tight (MY CASE... BRAKE DRAG for 13 months)... while another techs feels right, might not be tight enough (AS I SUSPECT IN SCHUKANUOSLADY'S CASE AND MY CASE SINCE NOV 08)
Just out of curiosity, how many clicks do you have to raise your parking brake lever in order to hold your 04 Elantra... when you put your vehicle in drive, while at idle and let off the foot pedal brake (I assumed you have an automatic transmission)?
I would think an over-tightening or under-tightening would be more due to not turning the adjustment screw the appropriate amount, but that is just conjecture.
P.S. What I actually was trying to say was that the 196N/20 kg/44 lbs spec seems to be common for MANY different cars, not just Hyundais. Try a Google search on those terms, especially 196N, and see what you get.
I think one of the things I'm going to check on when we make another purchase is HOW OUR NEW CARS SERVICE DEPARTMENT MAKES THESE ADJUSTMENTS AND REALLY LOOK HARD AT SOME OF THE THINGS YOU MENTIONED IN YOUR OTHER POSTS BEFORE WE COMMIT AGAIN ...I see, you pulled the trigger yesterday... how do you like your new VW Jetta?
THANKS
BigJay09
I started to hear squealing in my front brakes in September 2009 so I took the car to a shop right next door to where I worked. They told me both front and back brakes were shot. I asked them to replace my front brakes, but that I would take the rear brakes back to the dealership since they should still be under warranty. I was told it was still under warranty and that it must just been a fluke and they would replace the rear brakes again. They did the work and told me that it turned out I was actually 3 days out of warranty but they were being good guys and would cover the cost.
In July 2010 I heard squealing again in my rear brakes. I took the car back to the dealership and was told that the brakes were shot for a 3rd year in a row. I was told by the service manager that because I was not charged for the brakes being repaired 3 days past 1 year in 2009, even though the brakes had worn out again in less than a year, I would have to cover the cost of the repairs. They tried to tell me that it was normal for the brakes to wear out in 1 year or 10,000 miles. I pushed them on the issue and made a fuss, including called other dealerships. The service manager told me that he would look into the issue closer and they said there was something that was loose (maybe a caliper) that was dragging on the brake and that was the issue. They charged me to replace the brakes again (the caliper was repaired under a warranty contract I have).
It is September 2011 and for a 4th year in a row my rear brakes are squealing again. I do not want to pay for a new set of brakes if they are not going to figure out the problem. Please advise me what to do. I am supposed to take the car in Friday morning.
Back to your issue...when do your brakes squeal? While braking or always
Can you identify which side? Left, right or both
Can you easily see your brake pads? If not, can you remove the tire on the side or sides that are squeal?
Are the brake pads worn to the replacement indicators (metal taps that touch the rotor)
If yes, and you have only driven 10,000 normal miles (not 10,000 miles of in New York City stop and go driving) then you probably have a caliper that is not fully retracting (slides not lubricated or dirty or a bad caliper)
Good Luck with this and Make sure to get all parts replaced by the dealer (pads, rotors, calipers) unless you don't have to pay for anything!
First of all when I put the car in reverse and start backing up it makes a horrible loud grunting noise. When I apply the brakes to stop at like a stop light it also makes a irritating squealing noise as the wheel turns.
I had the caliper replaced last year because they told me the boot over it had come off and the caliper was exposed causing the caliper to go bad. They replaced the caliper and the rear pads and told me everything should be good.
I am not mechanically inclined and because of medical issues can't get down to look at brake pads, but I was told when I brought the car in today that there is absolutely nothing wrong with the car and that it is just normal wear for in city driving. I live in a suburb of Sacramento in California. I drive 9 miles each way to work which takes me 20 minutes. I have to stop about 7 times at stop lights each way. I asked if it is possible that they aren't adjusting the parking brake correctly and therefore maybe it is causing the brake to rub constantly. They told me there is no way that would be happening, it would cause the brake to wear way to fast and they would be able to tell. I guess I am going to have to just pay $300 each year to get my brakes done. The funny thing is that I did the same amount of driving and on the same exact route in my 2001 Saturn and I didn't have to replace my brakes but once in 60,000 miles. Now I am replacing them every 10-12,000. I will never buy a Hyundai again after this.
Which brakes did you tech replace or what did they do to fix the problem?
Front, back or both
Replacing brakes (pads and or rotors) at 10 -12 K in NOT normal. Taxi driving in all day long in stop and go (maybe), but not what you have described. I know Sac can have a lot of stop and go on the freeway during rush HOURS, but if your tech is telling you this type of replacement is normal, I would get a second opinion.
Maybe your tech is replacing parts with inferior pads, rotors or calibers. Did you get the old parts from this most recent repair?
Do you use the parking brake at all (would only affect the rear brakes)?
They replaced the rear left and right pads, and resurfaced the rotors to 18.1mm. I did request the old parts back. They gave me the brake pads which when my Dad looked at them he said it looks like they are wearing at an angle. Not sure if that is normal for a Hyundai. The box from the new brakes shows they are using Hyundai brake pads. They were very very dirty though. Couldn't even touch one without our hands being covered in black dust.
I only use my parking brake when I park, and have not even once forgotten to take it off before driving away.
My Dad asked them what the runout on the rotors was and they told us that they will not check the runout on the rotor unless there is complaint of pulsating. My Dad said that is crap because I brought it in for a 4th time due to the pads wearing out too soon, which is a problem, and therefore they should have checked the rotor to make sure it isn't warped. They told him that they have never done that and no one would have done that under these circumstances.
I have sent an email to the Hyundai Corporation and to department of highway safety and transportation, and the bureau of automotive repair to see if they can tell me what to do next. There is no way I can see having to pay $300 every year to replace rear pads. We also asked what the ratio is for my car for wear on front brakes compared to rear brakes and they said the front ones will last maybe twice as long as the rear ones.
Nov 25, 2011 Front brake servicing, clean and adjust rear shoes, lube backing plates 62,948 km
June 14, 2011 Pads and rotors for Right Rear brake only
Oct 20, 2010 Pads and Rotors Rear 47,604 km
July 31, 2009 Rear Pads and Rotors
May 1, 2009 Front Pads 56,178 km
