09 Forester Towing Performance
Have never owned a Subaru before, but am considering new MT Forester. I live in Montana. I tow a 1,950 lb camping trailer twice/month up into Yellowstone & twice/year down to SW US, driving on interstates & 2 lane black tops in the mountains. I need help trying to evaluate if the Forester will perform OK with my trailer & the 2,400 lb towing rating. Any help, expereinces, opinions would be useful. Thanks folks.
So, yeah, the Subie can "tow" 2400 pounds, it'll just have trouble "stopping" 2400 pounds if there are no trailer brakes.
Bob
Nick
Honestly, the Forester tows the big trailer better than the Honda Pilot we used to own. Sure, you feel it, but it tows it fine even at highway speeds.
I've towed with my wife's '01 Forester automatic, and it did fine (5x8 utility trailer rated for 3K). As you may already know, in other markets Foresters and other Subies are rated to tow over 3000 pounds. Here's the spec sheet from Australia (note that the manual gearbox down there is a dual-range unit).
http://www.subaru.com.au/models/forester/x/wagon/specifications/all/
1,400 kg = 3086 lbs
My only concern is that you're going to be using a manual gearbox, in which I'd worry about the clutch. Automatics are generally considered better for towing. The other thing, unlike in Oz, the US-spec Forester now comes with a temp spare tire; not a good thing IMO, for towing duties. Our '01 Forester came with a full-size spare. You might consider replacing that temp tire with a full-size unit.
Bob
Thanks very much for your information.
I am begining to feel better about the Forester. How much wieght to you tow in your 5x10 enclosed trailer? And what distances do you tow it with weight?
Thank you very much for the Australian information. That was very helpful. I am more confident about the Forester as a prospective auto.
What distances did you tow your utility trailer and how close to the 3 K was it when you towed?
I have a 2001 legacy GT sedan - we've towed lots of stuff with it over the years. 2000lb towing capacity. We have a sailboat and all up weight behind the car tips in just a touch over 2000lbs. Car towed the boat fantastic stopped fine better then the old Fords we used back in the day. Only issue was outside temps vs the cooling capacity of the car. The 09 forrester has all the cooling issues addressed though I would highly recommend the added oilcooler for your towing needs. Cool cars are happy cars.
150,000 miles on the old subaru and still ticking. No major issues though our crap not our boat has outgrown the subaru's sherpa capability so we have an old landcruiser that hauls the boat and all the regatta junk that goes with it now.
Enjoy your Subaru!! I'm a first time owner and will say with no doubt our next car will be a subaru no questions about it. They aren't the fastest - the best looking but they sure take one hell of a beating and just keep going.
19mpg towing the low profile 2000lb boat - 24-25mpg towing the smaller 600lb low profile sailboat.
The forrester would do fine though the outback would be my choice slighly larger platform slightly longer wheelbase and you get more floor space behind the back seat. Outback is just as capable as the Forrester off road except for the approach angles on the bumpers.
I've towed anywhere from 1,200 to 2,000 lbs (total weight, trailer + cargo). Again, no problems towing that amount of weight.
Same with the self-leveling rear suspension; bring it back over here, as it would be great for those who tow.
Bob
-mike
Subaru Guru and Track Instructor
Replying to: crv16 (Jan 26, 2009 7:47 am)
...Which is why I wish they would bring back over here the dual-range 5-speed manual tranny, which has a gear reduction ratio of only 1.196:1, which (I believe) can be shifted on the fly. This would be great for those of us who tow. It's offered on Foresters, and some other Subies, sold in many other markets.
Bob
I agree on the self-leveling. I have them on my Armada and they are great. I wouldn't hold my breathe on a 5MT anything, let alone a dual-range gear box showing up. If anything look for the MTs to be going away, as we have seen in the Turbo Forester.
-mike
Bob
Yes, it's far more "challenging" to drive over there, than it is here, for a variety of reasons well beyond what you stated. Therefore it's even more confusing to me as to why their trailer tow limits are so much higher than they are here. If anything—because of the more difficult driving conditions—the trailer tow limits should be less than those found here, but that's not the case.
Bob
If you have a trailer with brakes you may need an adaptor, but I think you'll be fine at under 2000 lbs even for good distances.
Remember folks, the OP is only towing 1950 lbs, with trailer brakes.
The clutch slips a bit with the 1500 lbs load, but I never had problems.
We now have a 2009 model but no tow hitch on this one. Trying to talk my wife in to that still.
I may put one on my Sienna instead.
Same issue with clearance at the rear, though. The factory one is tucked in nicely but you have to cut the bumper IIRC.
I just noted that the factory hitch requires slight bumper modification.... on my new car?!
My OE hitch on the 98 did not require any modification, bumper or otherwise. Bummer that changed.
Did you lose much of your departure angle? i.e. does it stick down a lot below the bumper?
Cool.
Share with us any towing experiences, if you will, good or bad.
Please do let us know your experiences and impressions as you use the setup.
>> the bumper?
> No, it is flush against the bottom of the bumper...
So you lost some departure angle. the OEM hitch is in the bumper, and replaces the car's bumper bar.
