oil presure gauge problem
                    Have an 02 dakota 3.9, oil gauge was reading low to high so I did an oil change with a qt of lucas oil and a new sendung unit, now when I start it the oil pressure is high and when it warns up it returns to nomal. But when I hit the gas it moves to 3/4 line and when I slow down to a stop it slowly returns to 1/2 way nomal spot is this nomal or should I look deeper?
At full operating temperature in summer, healthy, low mileage 3.9s typically idle at about 35-40 pounds oil pressure with fresh 5W30 motor oil and the correct oil filter (factory spec. minimum is 6 lbs.). Cold starts and colder weather usually raise the pressure at idle speed slightly. The oil pressure bypass in the engine is calibrated to open at 80 lbs. at 3000 RPM. At moderate highway speeds LA-series engines will typically produce 50-60 lbs. pressure.
High mileage (150,000 and up) and engines not well maintained will produce lower pressure numbers.
Best regards,
Dusty
